4l80e swap taking off in high gear
Old Jul 12, 2014 | 10:44 PM
802mtown's Avatar
Default 4l80e swap taking off in high gear
Hi I've been reading up on here for awhile and decided to build a turbo truck so thanks for all the help now I need a little more as I Did the 80e swap on a 07 seirra Classic had the trans rebuilt and swaped the brown and white wires at the trans connector and added the front iss connector and all that good stuff so went to test it out and the truck goes in reverse fine but in the forward gears it acts like it's in high gear so I unplugged the harness and it takes off easier but dont shift. What could this be? Any help would be appreciated
Old Jul 12, 2014 | 11:19 PM
Chevy_King1500's Avatar
any codes? what software are u using?
Old Jul 12, 2014 | 11:23 PM
802mtown's Avatar
Just maf codes as it's just laying on the fender. I took the truck to get tuned and the trans was going forward in all gears so didn't get much tuning done but I believe he used hp tuners
Old Jul 13, 2014 | 12:30 AM
Suburbazine's Avatar
So you got the wires, but did you have the tune segment swapped yet? Sounds like you didn't.
Old Jul 13, 2014 | 12:47 AM
802mtown's Avatar
That's what I was wondering cause I asked my tuner and he said he put a 80 tune in it
Old Jul 13, 2014 | 01:33 AM
1FastBrick's Avatar
Custm2500's Rude Friend
You also can't just leave the MAF hanging on the fender. It needs to be hooked up to some sort of intake system.
Old Jul 13, 2014 | 10:03 AM
802mtown's Avatar
Yea I just hooked it up cause it was goin into limp mode it needs to be tuned out
Old Jul 13, 2014 | 10:43 AM
802mtown's Avatar
Y'all think it's in the tune or is there something else I need to check?
Old Jul 13, 2014 | 02:35 PM
80E tune or 80E segment swap? You can't just toss the values from an 80E into a 60E table. The methods for commanding shifts and the wires needed are different. A 60E tune can try to skip from 1-3 whereas an 80E transmission must shift sequentially.
Old Jul 13, 2014 | 04:20 PM
802mtown's Avatar
Ok so guess I'll see if I can find someone to look at the tune and see if the segment swap was done. Also wondering if the 80e should shift without in plugged in or does it just default to one gear?
