4L80E Swap Question
Old Feb 22, 2010 | 01:16 PM
the_merv's Avatar
11 Second Club
Default 4L80E Swap Question
I read through the sticky's I found and couldn't find this answer..
I want to install just a stock 4L80E with Stock Stall into my 1999 5.3l Sierra.
I know the 6.0l uses that 1/2" Crank Spacer, so I will find that when it comes time cause I will need that aswell.
The question is what Flex Plate and Starter will I need to make this work properly?
Thanks.
Old Feb 22, 2010 | 01:51 PM
thunder550's Avatar
High on diesel fumes
4L80E flexplate (flat), and your existing starter will work.
Old Feb 22, 2010 | 01:59 PM
the_merv's Avatar
11 Second Club
Ah..ok..so they have the flat ones like the old 350's..cool. I'm used to the beveled ones in the 5.3's, and the LS1's.
Another quick one..I read the Transfer Case Sticky..is the best bet to get a 241 Case with the 4wd 4L80E if I come across one like that?
Is the 241 the Electronic one?
I don't know a whole lot about trucks..learning here..lol
Old Feb 22, 2010 | 10:26 PM
DrX's Avatar
DrX
NVG 241 is manual.
NVG 243 is 2 speed electronic selectable.
NVG 246 is 2 speed electronic automatic (Autotrac)
Old Feb 22, 2010 | 10:27 PM
GMCtrk's Avatar
Ive got a 4l80e flexplate I can sell ya if you need one.
Old Feb 22, 2010 | 11:52 PM
the_merv's Avatar
11 Second Club
Originally Posted by DrX
NVG 241 is manual.
Ok, so which one would be in most of the Trucks that have the push-button 4wd?
Old Feb 23, 2010 | 04:52 AM
DrX's Avatar
DrX
NVG 246 (RPO= NP8)
But make sure you get one that originally came behind an 80E. It will have the 32 spline input gear.
Old Feb 23, 2010 | 05:08 AM
the_merv's Avatar
11 Second Club
Ah..ok. That is the one that I will have to swap the Encoder Motors. Thanks.
Old Jun 11, 2010 | 07:32 PM
jophuss36's Avatar
What do you keen swap the encoder motors?
chadjcompton
17
Jun 21, 2022 08:47 PM
XL7
May 5, 2022 01:48 PM
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
lxcoupe
Jul 14, 2015 10:14 PM
