4L80E swap guys
Old Nov 29, 2006 | 03:24 PM
LIL SS's Avatar
Default 4L80E swap guys
Few questions:
What wiring harness / PCM are you running? (Year, Model)
If it was not a harness for a 4L80E how did you do your connector?
1) Use a cut off 4L80E connector and tap in to the harness / pcm
2) Repin a new connector in to the harness / pcm
3) Other (please explain)
What did you use for programing in regards to comanding the 4L80E perameters?
I think that's all I have for questions right now. Thanks in advance.
Old Nov 29, 2006 | 03:57 PM
quicksilverado's Avatar
You can get a harness from Speartech for about 100.00 shipped. You will need tuning on the pcm with hptuners.
Old Nov 29, 2006 | 04:13 PM
04BlackSilverado's Avatar
I'll be getting the Speartech harness, and I have HPTuners to program the transmission.
Old Nov 29, 2006 | 05:27 PM
XLR8NSS's Avatar
Adkoonerstrator
Yep, there is a conversion harness to adapt the 4L60E harness. Speed Engineering sells it also. With the 4L80E you will also need a second VSS sensor which speed sells too, it comes with instructions on how to pin it into the PCM.
http://speed-eng.com/store/product_i...oducts_id=6625
Any of the popular tuning softwares can reflash a 80E file into your PCM. When you reflash the PCM you need to flash the ENTIRE Operating system from a 80E truck into it. Whatever software you use look for a file from a 6.0L/4L80E/2wd truck, that will be the best starting point for you.
What year PCM do you have now?
Old Nov 29, 2006 | 08:00 PM
Wilde Racing's Avatar
How do I change this text
That is how I did mine, start with a 80e bin and tranfer all your engine tables over... I also went with the Speed Speartech harness....
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
dantheman1540
Jul 24, 2015 01:50 AM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
