4l80e swap dimensions for crossmember..
Old Mar 6, 2009 | 11:09 AM
rcmobile's Avatar
anyone??
Old Mar 12, 2009 | 11:14 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Originally Posted by rcmobile
anyone??
6-1/4 is for 99-02 trucks as I know. Not sure about the 03+.
Old Mar 12, 2009 | 11:30 PM
GMCtrk's Avatar
I'm pretty sure he already got his 80e in.
For anyone wondering measure the distance from the front of the bellhousing on your 60 to the stud that mounts to the crossmember. Subtract that distance from 30 5/8 and you will have the exact amount to move back the x-member.
Old Mar 13, 2009 | 10:45 AM
rcmobile's Avatar
yea thanks i did it, i moved the center back 6.25 and it was perfect.
Old Jul 6, 2009 | 10:18 PM
Blown02Sierra's Avatar
What did you 4l60e to 4l80e swap guys do about mounting the trans to the bracket? I was about to cut my bracket to move a section back but the rubber bushing spacer thing has no way of mounting to the 80e. Did you just let the tailshaft drop ~2 inches and drill new holes so the 80e contacts metal to metal on the crossmember?
EDIT: I've come to realize that 4wd and 2wd crossmembers are much different.
Old Jul 7, 2009 | 10:24 AM
silver-mod-o's Avatar
Hunt&Fisherator
which crosmember do you have?? the square tubing crossmember. or the tall raised center one...
If you have the square tubing x member, cut the mount off, flip it backwards, weld it back on, and youre done... works on mine, fits perfectly.
Old Jul 8, 2009 | 12:15 AM
I have the square non-raised one but I converted to 2wd from 4wd.
Old Jul 8, 2009 | 03:14 AM
Parke10's Avatar
i was wondering about this, i was lookin at a cross member the other day for a 80swap into a 99 and it looked like it had been cut, flip and rewelded but i wasnt sure on that.
Old Jul 8, 2009 | 04:18 AM
00Silv4.8's Avatar
I measured mine from my 60e to the 80e I was putting in. I believe it was like 5 3/4 on mine. I flipped my trans mount around for a better fit. Best thing to do is measure bell house to bolt on both trans and then cut and weld from there
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
chadjcompton
17
Jun 21, 2022 08:47 PM
XL7
May 5, 2022 01:48 PM
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
