4l80e swap conversion u-joint question
Old Nov 19, 2015 | 11:08 AM
Merctech2's Avatar
Default 4l80e swap conversion u-joint question
I have the yoke shaft from the donar truck and went to put the 447 ujoint on and the cap size is correct but the yoke is too wide. Went back to napa and they said they don't have anything else that size. Anyone else have this happen. Only thing left to complete the swap. Btw it's a 2wd
Old Nov 21, 2015 | 03:32 PM
James B.'s Avatar
If you're referring to the slip-yoke on the 4L80-E it should be a 1350 joint. Half ton truck driveline should be 3R, but I don't know what year truck you have. There is a conversion joint to go between 3R and 1350 but it's not available with a solid center.
Old Nov 22, 2015 | 07:28 AM
Merctech2's Avatar
Yes the slip yoke. The best I can tell the donar truck had a 1410 slip yoke. So I kept the 447 u-joint and ordered a slip yoke in 1350. I will find out when it shows up if my research is correct.
drexel
Dec 1, 2015 01:04 PM
carid
Nov 23, 2015 09:37 AM
vipergtrdj
Nov 20, 2015 02:29 PM
ChevyThunder17
Nov 19, 2015 03:31 PM
Cowboy Tom
Nov 16, 2015 11:18 PM
