4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....
#382
Or grab the tailhousing and lift up and down and left and right really hard until it cracks that seal. Sounds like you tried that already though... it's way easier on a lift when you're standing. You could also try taking a plastic mallet, thread in a tc bolt a few threads and smacking that with with the mallet, turn motor over and repeat for all. But I think the tailshaft method is best. Maybe put a jack under it and raise it up some. You just gotta get aggressive with it.
#383
Shook the **** out of it.
Would heat on the housing help where dowels are? Water hose prepped and ready of course.
Strap and ratchet around rear axel to tail of trans to pull?
My arms are sore. Fuuuuuuuck! Anyone live in Northern VA with big muscles and smarts? I'll pay for gas, food, beer and you can crash in our spare room. I'm married and not rapey.
#384
Heat directly on the dowel face absolutely can't hurt. I'm sure most will agree, and I can't tell you how many times I soaked something for a day or longer, cussed my mind out, only to have heat break it free nearly immediately.
Did you try jacking up the tailhousing until the top of the trans touches the trans tunnel? Sometimes changing the angle of things can be the magic ticket.
All in all sounds like an east coast problem.
#385
I'll need to adjust some things then try cranking the trans up to the tunnel. Good idea on trying different angles. I'm busy till late tomorrow but will soak the 2 dowels again. Then heat Wednesday and try again.
There's only 2 dowels right?
#386
Good to know about heat. Yes, east coast salt baby. I'm coating the pins with anti seize on reinstall. I coat most things with that or a ton of grease.
#388
All I'm saying is that you live in VA and he lives in VA. Why are you not helping him pull an all nighter? Jus sayin, you can drive all across VA in like 4 hrs.
