4L80E Questions for my nnbs RegCab
Old Dec 18, 2012 | 12:40 PM
07blksilverado's Avatar
Default 4L80E Questions for my nnbs RegCab
I have a new bodystyle Silverado 1500 2wd Reg Cab. I just put a 6.0 in it an wanna switch to a 4l80. Can I use a 4l80 out of a older bodystyle like a 03 or something? If so what do I need to go with it? I already know about the tuning an cross member issue an wiring issues but as for the trans it self will it work? Or what do I needa change on the trans it self? Thanks for any help
Old Dec 19, 2012 | 07:11 PM
schino's Avatar
just thinking off the top of my head, you will need the speed sensors in the trans since its got 2 vs 1. i cant help you as far as the flex plate and converter go because im running a circle d converter with a 60e bolt pattern.
Old Dec 19, 2012 | 07:16 PM
Circle-D's Avatar
Former Vendor
If you are trying to use the OE 310mm 4L80 converter, you will need the OE style flat flexplate and the crank spacer. If you are looking for a custom converter, we can build you one with the LS bolt pattern to fit your dished flexplate - no spacer needed.
Chris
Old Dec 21, 2012 | 05:45 PM
Alright sounds good Circle D! Thanks Chris
Old Dec 21, 2012 | 05:49 PM
Will the trans work after I get the converter?
GXPJAY
Feb 13, 2022 08:15 AM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
alex226
Jul 16, 2015 10:55 AM
blackdc3
Jul 7, 2015 07:52 PM
