4l80e question
Old Jun 10, 2007 | 09:58 PM
sdimess84's Avatar
Default 4l80e question
Are there any differences in wiring between an older style 4l80e like out of a 97-98 truck and a newer 4l80e, out of a 2000 or newer?
I have an older 4l80e trans, but i think my custom wiring harness that I had made was meant for a newer one(if there is a difference). I am having a check engine light come on about my TCC PWM solenoid. Thats why I was asking. Trying to figure out if its a wiring, programming, or sensor problem.
Old Jun 10, 2007 | 10:19 PM
FLT's Avatar
FLT
FormerVendor
The wiring is the same on those two units.
Old Jun 11, 2007 | 05:09 AM
mkufamous's Avatar
does the level 5 480le tranny comes with an overdrive or can you add overdrive with the drive in your set up. currently i have 4l65e tranny with drive and overdrive.
Old Jun 11, 2007 | 07:17 AM
FLT's Avatar
FLT
FormerVendor
It is a 4 speed automatic.
Old Jun 14, 2007 | 12:56 PM
sdimess84's Avatar
Does anyone know about what rpm range the should I be at cruising about 60mph with the converter locked up? I am running 245/60/15 wheels, older style 4l80e, 3.42 gears. Im just curious
GXPJAY
Feb 13, 2022 08:15 AM
Rafe19
Oct 18, 2016 12:27 AM
wcrum17841
Aug 24, 2015 08:30 AM
USMCvet0311
Aug 1, 2015 07:45 AM
