4l80e and np242 drag truck
I'm trying to plan an AWD street/strip truck with a 4l80e and a np242 (Hummer t-case) The engine will be a twin turbo 427,with 1500 ft/lbs torque or so. i need a front end gearbox solution, and ideas to beef the t-case. Also, same diameter wheels, can i run different width tires without burning the t-case?
camaro rear gearbox in front?
I would try the stock t-case first. It is dirt cheap from a salvage yard and if you blow it oh well you might try advanced adaptors for somthing a little more beefy but they cast mucho $$$
Sorry Parish I was just in from work and I cant spell for $hit.
You need a passenger side differential to use the 2500 T-case. A 2500 front diff would probably hold up.
zaathur151
Jul 6, 2015 10:57 PM
