4L80E not working
Old Nov 3, 2006 | 05:01 PM
mcarlson's Avatar
Default 4L80E not working
I have a 1993 Chevy 2500 with a 6.5 turbo diesel that kicks out of overdrive ! I have to stop and shut off the truck and then restart it to go back into overdrive! code says that there is too much slip from the imput to output sensors. This trans has just been rebuilt. it also has a very hard first to second shift! any ideas?
Old Nov 3, 2006 | 08:17 PM
Bowtie70SS's Avatar
There are 2 speed sensors on the trans...and you can plug them in wrong. Try switching the two speed sensor plugs. Later
Dave
Old Nov 8, 2006 | 04:58 PM
mcarlson's Avatar
nope not it any more things i can check!
Old Nov 8, 2006 | 05:11 PM
cablebandit's Avatar
9 Second Club
stock stall?
Old Nov 8, 2006 | 05:25 PM
Bowtie70SS's Avatar
Throttle position sensor? I have heard that these go bad on diesels and cause the trans to act funny.
Dave
Old Nov 8, 2006 | 07:04 PM
FLT's Avatar
FLT
FormerVendor
OHM the speed sensors and see if they are the same.The hard shift is probably the computer putting the trans to a high line pressure setting because it is seeing a problem. I do have new speed sensors if you need them.
Old Nov 8, 2006 | 08:41 PM
Bowtie70SS's Avatar
I have a friend who rebuilds trannys and he ran into a problem a while back. One of his customers supplied a kit for him to use on a rebuild and the filter they included with the kit was crap. My buddy built the tranny, installed it and drove it. Worked fine for about 200 miles till flimsy filter sucked closed and caused the trans to slip (E40D/6.9 diesel). Trans came out again, checked, reinstalled, pan dropped 2X before he figured out it was a bad filter. It's something easy to check anyway.
Dave
Old Nov 10, 2006 | 08:09 PM
FLT's Avatar
FLT
FormerVendor
I read a bulletin today about a fuel pressure sensor on the injector pump causing wierd 4th gear and lock up problems. Maybe something to think about as well. Vince
Oobray
Jun 13, 2022 03:38 AM
XL7
May 5, 2022 01:48 PM
Rafe19
Oct 18, 2016 12:27 AM
brandon6.0
Aug 19, 2015 07:48 AM
lycominghunter
Jul 29, 2015 04:24 PM
