4l80e neutral safety switch mounting
Old Nov 7, 2006 | 07:17 PM
adam1803's Avatar
Default 4l80e neutral safety switch mounting
Well i just got a call from bowtie overdrives and they told me that the 4l80e i ordered from them was built and then they got a call from someone else doing a 4l60e-4l80e swap and was told the neutral safety switch wouldn't mount to the 4l80e they were sent. They wanted to swap all the parts to a different case but i told them i really needed it right away so i would find a way to mount it, like make a bracket or something. I was unaware that there were different cases made for the 4l80e.
Has anyone else ran into a problem like this, and if so what did you do to make it work?
Old Nov 7, 2006 | 08:39 PM
Wilde Racing's Avatar
How do I change this text
Yes I have ran into this problem, but what I did aint going to help ya. I sent mine back. lol
I think you could come up with something, It just might not look like a show car if you know what I meen.
Old Nov 8, 2006 | 06:05 AM
adam1803's Avatar
I don't care much what it looks like, as long as it drives. The 6.0 swap has been finished for almost 2 months and so has the 4l80e swap, but i've gotten 2 bad trannies from the salvage yard so its been off the road for what seems like forever.
I'll crawl under the truck tonight and see what i can do to fab up a bracket for it. I guess i could just tack weld it to the case, lol
Old Nov 8, 2006 | 08:51 AM
Do you still have the two junk 80es? Maybe a trans shop could swap cases for you...
Old Nov 12, 2006 | 02:56 PM
adam1803's Avatar
no, they have both been returned to the salvage yards they came from. I made some brackets for it today to use two of the pan bolts to hold it in place.
Old Nov 12, 2006 | 04:36 PM
FLT's Avatar
FLT
FormerVendor
It sounds like they built you an early unit. I would ask them if they intalled the long linkage for you. You will probably have to do a little work with the cooler lines if you are using steel lines. Is your motor ls1 based? If so you will probably loose one of the bolt holes in the bell when bolting it up.
Old Nov 12, 2006 | 05:05 PM
I'd let them swap cases,I tried a early 4L80E for a while and it never was right.You don't want to zip tie the nuetral switch into place and it sure would be nice to be able to shift the tranny into 1st gear with the gear selector.Do youself a big favor and opt for the late model case.
Old Nov 12, 2006 | 10:21 PM
adam1803's Avatar
Im not using all steel lines for the trans cooler so thats not an issue, and the switch will be firmly mounted using my brackets i made. As long as i don't run into any major issues im not going to worry about swapping the case.
GXPJAY
Feb 13, 2022 08:15 AM
GM1697
Sep 2, 2015 08:32 AM
Fast86z
Aug 23, 2015 12:35 AM
stock48
11
Aug 18, 2015 05:55 AM
