4l80e max rpm?
Old Apr 12, 2013 | 04:16 AM
TURBHOE's Avatar
Default 4l80e max rpm?
Is there a rpm for the 4l80e where the clutches try to engage due to centrifugal force? Seems like I read that the 60's don't like real high rpms, so I'm wondering about the 80e before I choose some build stuff for my 6l.
Old Apr 12, 2013 | 06:09 AM
03sierraslt's Avatar
None that I am aware of, complete different design.
Old Apr 12, 2013 | 08:50 AM
TURBHOE's Avatar
ok so if i wanted to wing it to 6500rpm it would be fine?
Old Apr 12, 2013 | 09:09 AM
Don't see why not, I will be taking mine to that and used to take my 65e to 6400 all the time but my 65e was built to do so.
Old Apr 12, 2013 | 09:26 AM
slow67's Avatar
Gingervitis Addict
If there isn't a hole drilled in the direct drum, you can centrifugally apply 3rd gear clutches while in 1st at a high RPM.
Old Apr 12, 2013 | 09:36 AM
TURBHOE's Avatar
so the builder will probably need to know if your going to be turning a decent rpm? i never took my 60e over 6200 unless it missed a shift but then i had the tb close around 6300 just to be safe.
Old Apr 12, 2013 | 09:37 AM
Heavier direct clutch return springs help combat this issue does it not?
Old Apr 12, 2013 | 01:54 PM
slow67's Avatar
Gingervitis Addict
They help, but many "race" transmission builders (who are experienced in th400s) already drill the direct drum bleed hole.
Edit: I guess it would make a difference if we are talking a stone stock transmission or one that is/has been rebuilt.
Old Apr 12, 2013 | 03:10 PM
TURBHOE's Avatar
Either way these are things that are good to put out there. That way people will know not to just throw in a shift kit and go spin their motor to 7,000 and wonder why the Trans went. I just remember seeing it on a random thread years ago so I decided to ask.
I want to do the Holley intake on my 6L and I need a new cam, so I figured might as well get the cam to match the I take if the Trans can take it. I don't want 7,000 but 6500 would be ok.
chadjcompton
17
Jun 21, 2022 08:47 PM
Oobray
Jun 13, 2022 03:38 AM
Slow94Formula
Nov 15, 2015 09:23 PM
zachman078
Sep 21, 2015 04:36 PM
lxcoupe
Aug 31, 2015 05:49 PM
