4L80E input shaft o-ring....
After receiving my second aftermarket torque converter that will not engage all the way, I decided to try it without the o-ring on the input shaft and it fit fine. Re-installed the o-ring, converter didn't engage all the way again. Anyone else ever had a problem with the oring rolling out of the groove causing the converter not to slide all the way in? I am wondering if I need to get another tranny specific o-ring from GM or go to an industrial supply store and get a tighter fitting o-ring? Maybe even a rubber o-ring that is a little smaller that will swell a bit once the ATF hits it?
Are you using a factory input shaft? I have seen with after market shafts and converters. I use a seal lube stick from sonnax to grease the **** out of it to avoid this problem. You can also use a product called door-ease to do this. I have found this product in a hardware store at times. Good luck Kid!
