4L80E fluid lines - opposite of 4L60E?
Old May 22, 2006 | 03:07 PM
thunder550's Avatar
High on diesel fumes
Default 4L80E fluid lines - opposite of 4L60E?
Are the fluid lines that come out of the 4L80E opposite of the 60E? Which goes out to the radiator and which is for fluid coming back in to the trans? My tranny runs lots hotter than the 60E did, and I'm thinking that it's because I have the fluid routed to the external coolers first then through the radiator. The tranny temp seems to always stick close to engine temp (saw 225 towing this weekend, and thats about where coolant temp was too), where as before it rarely got above 165 or 170 or so.
Old May 22, 2006 | 04:10 PM
kbracing96's Avatar
You went to the lake this weekend, bastered! How come you never went when I was there?
Old May 22, 2006 | 04:12 PM
thunder550's Avatar
Cause it was cold! Come back and go with us next time.
Old May 22, 2006 | 07:09 PM
Keith's Avatar
Lake pleasant?
Old May 22, 2006 | 07:38 PM
thunder550's Avatar
Bartlett...less people
Old May 22, 2006 | 08:27 PM
FLT's Avatar
FLT
FormerVendor
What year is your case? All center lube cases the front line is pressure. If it is an early case bottom line is pressure. Good luck!
Old May 22, 2006 | 10:22 PM
thunder550's Avatar
Not sure - how do I tell?
Old May 22, 2006 | 10:50 PM
parish8's Avatar
single digit dreamer
you can tell wich line is the feed by starting the truck when cold and puting your hands on the lines. see wich one gets warm first. thats the feed line.
Old May 22, 2006 | 11:05 PM
thunder550's Avatar
Duhhhh I can't believe I didn't remember that. Thanks for reminding me!
Old May 24, 2006 | 07:43 AM
FLT's Avatar
FLT
FormerVendor
WOW! Sounds like you know your trannies. You would be looking for a job? You are correct about the lines getting warm. I never look at it that way but that is a good idea.
