4l80e converter help?
Old Apr 10, 2013 | 05:27 PM
Ron_Stoppable's Avatar
Default 4l80e converter help?
i received my stall today from circle D. but it only has 3 bolt mounting tabs and i have the 6.0L flexplate with 6 mounting tabs, is everything going to work correctly?
Old Apr 10, 2013 | 07:11 PM
slammedsilvy's Avatar
I don't know if you can make it work with the 6.0 flex plate, but they sent you a hybrid with the 4.8/5.3 flex plate with 80e swap. Did your truck originally come with a 4.8 or 5.3? If so, you can bolt the factory flex plate back on there.
Old Apr 11, 2013 | 05:37 AM
its a motor i bought off of craigslist, it had a 60e behind but now it has an 80e so i swapped the flexplate to the 6.0 flexplate/ i thought the converter would have 6 mounting tabs like the flexplate but it only has 3?
Old Apr 11, 2013 | 06:26 AM
sorry i meant to say 6.0 flexplate with a crank spacer. if that makes a difference.just wanted to know if i could just use 3 bolt holes on the flexplate instead of the six because the circle D converter is listed as an 4L80e LS converter
Old Apr 11, 2013 | 08:04 AM
Circle-D's Avatar
Former Vendor
The 4L80 LS uses the LS bolt pattern. So you will need to remove the spacer and 4L80 flat flexplate and go back with the 60e style dished flexplate. Sorry for the confusion.
Chris
Old Apr 11, 2013 | 01:28 PM
so i need the truck flexplate? (dished) or am i ableto use a flexplate from an LS1 WS6 trans am, i know they are 3 bolt but are they dished?
Old Apr 11, 2013 | 02:27 PM
Circle-D's Avatar
Former Vendor
Any dished 4L60 will work... but it seems like the truck ones are a little stronger.
Chris
Oobray
Jun 13, 2022 03:38 AM
GXPJAY
Feb 13, 2022 08:15 AM
Slow94Formula
Nov 15, 2015 09:23 PM
bighouse
Sep 27, 2015 12:37 AM
lycominghunter
Jul 29, 2015 04:24 PM
