4l80e converter help?
i received my stall today from circle D. but it only has 3 bolt mounting tabs and i have the 6.0L flexplate with 6 mounting tabs, is everything going to work correctly?
I don't know if you can make it work with the 6.0 flex plate, but they sent you a hybrid with the 4.8/5.3 flex plate with 80e swap. Did your truck originally come with a 4.8 or 5.3? If so, you can bolt the factory flex plate back on there.
its a motor i bought off of craigslist, it had a 60e behind but now it has an 80e so i swapped the flexplate to the 6.0 flexplate/ i thought the converter would have 6 mounting tabs like the flexplate but it only has 3?
sorry i meant to say 6.0 flexplate with a crank spacer. if that makes a difference.just wanted to know if i could just use 3 bolt holes on the flexplate instead of the six because the circle D converter is listed as an 4L80e LS converter
GXPJAY
Feb 13, 2022 08:15 AM
lycominghunter
Jul 29, 2015 04:24 PM
