4l80e can anyone tell me about this one?
Old Mar 2, 2016 | 06:57 PM
Flewbyu123's Avatar
Default 4l80e can anyone tell me about this one?
I just pick up this transmission 4MPJ-MPI74 out of a 05 2500 Silverado. Google it and found out nothing.. Anyone know the scoop on this one?
Old Mar 2, 2016 | 07:01 PM
FFDP's Avatar
What are you trying to figure out?
Other than that it is a 4L80e from a heavy duty truck.
Suburbazine's Avatar
If it's an 80E it's like all the rest of them. I suspect you found the case production number.
Old Mar 2, 2016 | 07:17 PM
Flewbyu123's Avatar
p/n 24208421 with these letters on it MP-J
Old Mar 3, 2016 | 12:43 AM
Yep, regular 80E. For what it's worth, they're pretty much the same through all the years aside from a single bellhousing bolt hole placement (which doesn't matter).
Old Mar 3, 2016 | 09:28 AM
Flewbyu123's Avatar
OK Thanks .. Its what I will be soon doing my swap with.. You know what are the hard part I will need ? such as a flex plate? spacers? Doing the swap to a 2003 Chevy Silverado 5.3...
Old Mar 3, 2016 | 09:50 AM
madmann26's Avatar
You will need a modified tranny crossmember or a new crossmember.
You will need a tune with a segment swap.
I believe there is some wiring you will have to do with the 80e.
You will need a shorter driveshaft.
Dunno about the flexplate.
Old Mar 3, 2016 | 12:13 PM
dirt track racer 81's Avatar
Message me if you need a crossmember. Mine are $155 shipped..
Old Mar 3, 2016 | 12:19 PM
Wolftrk99's Avatar
Early 4l80s had the cooler line fittings much closer together also....
Old Mar 4, 2016 | 05:07 AM
Flewbyu123's Avatar
OK Thank you ali.. I will try to have all the things I need for next weekend. Sure would be nice to really open up this Procharger and not blow thru third gear!
