4l80e bottom cover problems
Old Nov 12, 2011 | 10:34 AM
tarinitup's Avatar
9 Second Truck Club
Default 4l80e bottom cover problems
So last night at the track truck made a horrible noise and seemed like converter was toast. jacked up the truck and cover was hanging by one bolt halfway in. New trans was installed last week and we made sure all bolts were tight cause this has happend before. Do we need to put lock tite, lock washers, or leave the MF off? Had it come loose it could have screwed something up or punctured a slick.
Old Nov 12, 2011 | 10:38 AM
silver-mod-o's Avatar
Hunt&Fisherator
on a truck like yours, I'd just leave that thing off.... I never had one on mine and for well over a year, never had an issue. I can see on super low street trucks that are driven in weather a lot and are suceptable to picking paper or whatever up off the road to have it but other than that I wouldnt worry with it.
If your **** is really on the ground my only worry would be sucking a damn grocery sack up in the bellhousing and killing the seal etc... other than that, run that hoe
Old Nov 12, 2011 | 11:11 AM
charcold-bowtie's Avatar
I agree^ what are the realistic chances of something gettin caught in it? pretty low IMO
Old Nov 12, 2011 | 11:44 AM
Coban's Avatar
Loctite is only a few bucks....
Old Nov 12, 2011 | 11:53 AM
tarinitup's Avatar
9 Second Truck Club
Screw it I'll leave it off. Should cool converter too.
Old Nov 12, 2011 | 05:49 PM
Beatdown Z's Avatar
Laid Back
I'm not planning on running one in my truck with a 4/6 drop. You'll be fine.
Old Nov 12, 2011 | 08:21 PM
sureshot's Avatar
I was thinking the same thing. You may luck out without running a cover, but some lock washers or maybe some blue loctite is only a few bucks.
Old Nov 12, 2011 | 08:43 PM
TIM Z's Avatar
11 sec. Truck Mod
Is this a common prob?
Damn im gonna check mine , thanks alot ( sarcastic ) haha!
Old Nov 12, 2011 | 08:49 PM
Gadgetized's Avatar
I don't run one. No problems here
Old Nov 12, 2011 | 10:39 PM
nonnieselman's Avatar
I havent run one since i did the 80 swap. Mainly cause i couldnt find all the bolts
Alot of off roading and mud later, the seal is leaking. So gotta fix that one day. Dont think you will have to worry bout gettin your 10 second truck in mud half way up the tires haha
