4l80e
#22
Formerly Low_LQ4 - 6/6/10
I am having some shifting issues and it seems that i can't get the right tune.
I'm workin on it now hope to get everything fixed by next week.
#24
Originally Posted by dmc_racer
All the parts can be found in SPEED-ENG
http://speed-eng.com/store/index.php..._940_1409_1713
here are part #'s
15000206 - Converter dust cover
12551367 - 6.0 Flexplate
12563532 - Crank Spacer
12553332 - Flexplate bolts (6 required)
15198439 - 4L80E Dipstick tube
15183801 - 4L80E Dipstick
15013290 - 4L80E Shift cable bracket at transmission
11589040 - 4L60/65/70/80/85E Toque converter bolt (6 required)
The tranny mount can be re-used because they use the same part number (15767858)
After doing some research i thought that you need to use a Crank Spacer but I ended up not needing it
keep in mind i used my old 5.3 Flexplate
here are part #'s
#27
Is it a segment copying problem (EFI Live?)
Or is it running fine but the shifts arent what you want them to be? You can PM me if you want. I learned alot this last week about tranny tuning, lol
#28
#30
Well crap. I cant see the tune then. If you know anybody around with EFI you can have them download your tune in .tun format and send it my way.
Quote:
Originally Posted by gmforlife
Yep pretty much it, you go into the tune repository on HPT, or get someone on here to get you a stock file, looks like you found someone to help you out with that, and basically copy over all of your engine settings to the new 80 file, don't just copy the tranny tables on the 80 file over to your current 60 file, won't work. Just wanted to clarify that. So you basically are using the 80 file, and copying over your motor and DTC's and what not.
Got it i'll try it tommorrow
Thanks alot
A.J.
