4l80e
Old Jul 1, 2007 | 09:35 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Thumbs up 4l80e
Been working on installing my 80E this weekend thought i might share some pix
All the parts can be found at SPEED-ENG
http://speed-eng.com/store/transmiss...3_78_1995.html
Here are the part #'s
15000206 - Converter dust cover
12551367 - 6.0 Flexplate
12563532 - Crank Spacer
12553332 - Flexplate bolts (6 required)
15198439 - 4L80E Dipstick tube
15183801 - 4L80E Dipstick
15013290 - 4L80E Shift cable bracket at transmission
11589040 - 4L60/65/70/80/85E Toque converter bolt (6 required)
The tranny mount can be re-used because they use the same part number (15767858)
Conversion Wiring Harness Upgrade
Old Jul 1, 2007 | 09:38 PM
Low_LSX's Avatar
Thanks Sean
from Speed-eng for the fast shipping and great service....
Old Jul 1, 2007 | 09:40 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Sweet. Take a bunch more. I'm starting mine on Thursday. Where did you get that crossmember?
Old Jul 1, 2007 | 09:47 PM
1SlowHoe's Avatar
Also, did you need the spacer for the flywheel? I have a 6L in the truck using my 5.3's flywheel. I have a spcer as well as a 6L flywheel with the spacer already welded on. I just don't know if I need it or not. The guy who set up this 80E before me said he had a 5.3 flywheel on his 6L with no spacer and the 80E hooked right up.
Old Jul 1, 2007 | 09:50 PM
Low_LSX's Avatar
Me and my friend made it
Old Jul 1, 2007 | 09:52 PM
Low_LSX's Avatar
I've got a 5.3 Flexplate and i only had to modifay it
bought the spacer and ended up not needing it...
am waiting for HPT to deliever my new VCM so0 i can tune it and test it out
Old Jul 1, 2007 | 10:06 PM
1SlowHoe's Avatar
Cool. Make another one.
Old Jul 1, 2007 | 10:22 PM
Low_LSX's Avatar
How much are you welling to pay??
Old Jul 1, 2007 | 10:34 PM
1SlowHoe's Avatar
Lol, I would be interested but I would need it by Thursday. The 80E I bought has one with it but I'm not sure its is going to line up because it was for a 03 model. I have access to a torch and metal if needed. Yours does look good. I bet you could find a few buyers if you made a couple more. I might even get one later after I am running again just to clean up the install. If you think about doing it, PM me a price.
Old Jul 1, 2007 | 10:54 PM
FLT's Avatar
FLT
FormerVendor
Nice looking cross member. Did you already get your pinion angle figured out? That member looks pretty damn solid!
