4l80 swap issues
no you would swap to an output shaft that is fully splined.
if you have a two piece drive shaft on your truck you could run a counter bored slip yoke. the first shaft does not move very much.(first part from trans to carrier bearing) most of the slipping. (in and out) is done from the shaft that connects the axle to the carrier bearing
I can get the driveshaft in but there is only about 3/8in of clearance.
How do I create more room ebtween the yoke and the non splined portion of the output shaft?
You want the TH400 short yoke. As for the not being able to attach the shift lever. I'm guessing you had a 4l60e before the swap. You have to use only 1 bolt on the pan to hold it in place. (YOU have to use the original 4l60e shift cable bracket) You'll see what I'm talking about when tour maneuvering the cable/bracket. You have to move it one or two bolts more forward so everything lines up or else your trans won't fully engage into park. My 80e is a 95 van trans, so it had the bolt on yoke.
