4L80 Swap
Old Sep 12, 2009 | 04:48 PM
BLKC3's Avatar
Default 4L80 Swap
Hi All,
Im new to this forum so a little intro. I have a 2001 c3 6.0 with a Whipple SC at 6lbs of boost, Wester's tune and a Flomaster mufler. After killing a couple of 4l65s I just finished a 4L80 swap. I drove the truck before I switched the wiring and the tranny shifted fast and crisp but no TC lock up. I finished the rewiring this morning- switched the brown wire with the white one on the trans connector and ran wires from the computer to the front ISS wire A to pin 22 wire B to pin 23 of the RED connector. After a test drive the tranny shifts slowly with some flairing and still no TC lock up. At least the SES light is off now. Did I do the wiring correctly?
Thanks
Steve
Old Sep 12, 2009 | 05:00 PM
RandomHero's Avatar
You did do a segment swap for the 4l80e right?
Old Sep 12, 2009 | 05:35 PM
BLKC3's Avatar
What's a segment swap, did not read or hear that term. If you mean updating the computer for the conversion, yes
Old Sep 12, 2009 | 09:00 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
A segment swap is when you convert the PCM and put an 80E file in it to make it shift right. You should go over my "4L80E" using the search function to make sure you got everything right.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Three6GMC
Aug 28, 2015 07:56 AM
SloSVO
Aug 11, 2015 07:33 PM
GM-only
Jul 19, 2015 10:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
