The 4l80 Stock Rebuild
Looking to get a parts list, prices too, of what it takes to rebuild a 4l80 to stockish form.
No hard parts, just the clutches and other serviceable stuff.
I plan on picking up a 80 in the next couple weeks that is known to have bad clutches, just wondering what I am getting into. Plan on doing a shift kit, and then I assume a stock rebuild would be fine for 500-600hp
GM 4L80E 4L80-E Automatic Transmission Master Rebuild Kit 4L85E 4L85-E Chevrolet GMC Chevy: Oregon Performance Transmission - Rebuild Parts for 700R4 4L60E 4L80E E4OD 4R100 47RE 48RE & More
or this:
GM 4L80E 4L80-E Automatic Transmission High Performance Master Rebuild 4L85E Kit Chevrolet GMC: Oregon Performance Transmission - Rebuild Parts for 700R4 4L60E 4L80E E4OD 4R100 47RE 48RE & More
IMO you will be fine with option 1.
or this:
I just rebuilt my 4l80e with ~100k miles on it, on teardown some of the clutches were damaged so I just re clutched the whole thing, had a box of gm clutches and trans parts laying around. These transmissions hold up well to wear, I didn't even replace the bands, only the clutches and my torque converter o ring was squared off. Put together with transgo kit and is holding up to supercharged WOT shifts without missing a beat!
Keep an eye open on the teardown and you should be fine.
Mine had probably 250k miles. It ran fine but I did all wear items just in case. I had some toasted bearings and hard seals on top of clutch and steel wear.
DeucesALLin
23
Jun 24, 2018 08:40 AM
FlowmasterMufflers
Nov 30, 2015 03:49 PM
