4L80 Slipping in 2nd after lots of spray
Old Feb 28, 2012 | 11:25 PM
Yohns Kustom Fab's Avatar
Formerly classic_speed (2015-06-02)
Default 4L80 Slipping in 2nd after lots of spray
Ive got a stalled 80e in my truck and its started slipping in 2nd gear. Every other gear is fine and smooth. Is it possible its just the second gear clutches or is there something more that could be smoked?
Old Feb 29, 2012 | 06:48 AM
slow67's Avatar
Gingervitis Addict
First thing I'd do is put a pressure gauge on it.
Old Feb 29, 2012 | 09:52 AM
What am I looking for with that?
Old Feb 29, 2012 | 06:35 PM
Vince B's Avatar
Intermediate clutch failure IMO is kind of common on these units and in some cases the sprag might be starting to slip. Slow is probably wanting to see if there is a pressure loss in 2nd gear. Is this a built unit or a bone yard conversion?
In the last month I have built a few virgin 80's that had some decent miles on them. The one thing I find is that the 1-2 accumulator seals really wear and in most cases have no resistance in the bore. The one unit I built recently the 2-3 and 3-4 accumulators were the same way and that unit was pretty cooked. When I removed the housing from the valve body the pistons fell out.
Now I guess we could assume that either the seals are worn or they have been over heated to cause this. Either way you need to look at this kind of stuff when determining a failure in a unit. I myself like to make sure to have a good AFL bore, use a stiffer spring behind the 1-2 shift valve, and also use a modified tcc valve in the valve body. From there always make use to address the bushings in these units and I feel that end play is very important in any build. HTH Vince
Old Feb 29, 2012 | 09:30 PM
Its supposed to be a built unit, hd sprags and hd2 shift kit? Ftl4000 stall.
Old Mar 1, 2012 | 02:04 AM
stock48's Avatar
9 Second Truck Club
X2 I have also seen this as well as the lugs on the case breaking off allowing the intermediate snap ring to be half hanging out just enough to let clutch slip. The case lugs were the death of my 4 yr old JY 80E.
Old Mar 1, 2012 | 03:24 AM
And here I am thinking an 80e is indestructible lol. I guess everything has its breaking point.
Old Mar 1, 2012 | 04:48 AM
stock48's Avatar
9 Second Truck Club
Better pull the pan and see how it looks.
Old Mar 1, 2012 | 08:20 AM
nonnieselman's Avatar
haha.. nobody said they are indestructable.. just really strong, but its still metal and clutchs.. something is gonna wear out at some point.
ferrellrooster
Mar 6, 2025 03:22 PM
blownss27
Aug 14, 2015 03:31 PM
sprayed99
Aug 4, 2015 09:09 PM
GM-only
Jul 19, 2015 10:48 PM
