4l80 segment swap for '05 Escalade
Old Jun 28, 2007 | 07:56 PM
gametech's Avatar
Default 4l80 segment swap for '05 Escalade
My neighbor is trying to find out what we need to change in the computer for a 4l80 swap in his 05 escalade. He has HPtuners model year licensing for the 05 escalade, and 03 and 04 silverado/sierra. I just can seem to find out if any of those other OS's are compatible, or if it is possible to just do the segment swap on the '05 file. Any input is appreciated.
Old Jun 28, 2007 | 11:18 PM
You'll need a conversion harness to correct the different pin locations and to add a second serial cable from the transmission to the PCM.You need to modify the crossmember to clear the pan and position the mount higher and further back.You'll the shift cable for a 4L80E to have enough travel to engage all the gears and park.Then a different segment file.
Old Jun 28, 2007 | 11:49 PM
gametech's Avatar
I have all of the above mentioned handled except for the pcm segment problem.
Old Jun 29, 2007 | 04:10 AM
Call John at Speartech,he's a sponsor at Ls1tech.
Old Jun 29, 2007 | 09:53 AM
kbracing96's Avatar
With HPtuners, I'm pretty sure you have to have then do the segment swap from what I've heard. Might want to get with ECTune on there board.
Old Jun 29, 2007 | 06:41 PM
gametech's Avatar
ECtune is on vacation, but he replied to me anyway. It sounds like the problem will be solved.
Old Jul 1, 2007 | 07:28 PM
Bill Reid's Avatar
EC Tune is who will do my segment swap as well... anybody know the PCM pins that need to be tapped for the input shaft sensor? I assume the rear speed sensor uses the existing plug from the 4L60E...
Thanks,
Bill
Old Jul 1, 2007 | 07:35 PM
nick993's Avatar
the 6.0HO doesnt come with the 4l80e?
Old Jul 1, 2007 | 11:52 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Thanks,
Bill
Pins 22 & 23 from what I have read. There is thread right now about it....
https://www.performancetrucks.net/fo...d.php?t=396059
Different model year may be a different pin out.
Old Jul 2, 2007 | 07:05 AM
Bill Reid's Avatar
I found it... silly me... it is in the eSi software I have. Here it is for future search reference...
