4L80 conversion?
Old Aug 13, 2007 | 11:13 AM
Slowhawk's Avatar
LS1Tech Sponsor
Default 4L80 conversion?
Who's done it?
I was looking at the speed engineering kit hoping it is 100% complete. This will be going into my 05 Avalanche. I don't see the point of building up the 4l65 since a bigger motor will be in the future.
Old Aug 13, 2007 | 12:24 PM
LIL SS's Avatar
I have an 80E in my 63 P/U. It's a little different since your starting from a truck harness and PCM, but it's simple enough to swap the harness pins at the tranny connector instead of buying a adapter. Also since your already using a truck PCM, I believe you just need to reflash the PCM with the 4L80E settings in place of the 60E settings once the pins are swapped.
Using an F-body PCM I had to have HP tuners merge the F-body and Truck OS to make it work.
Old Aug 13, 2007 | 04:31 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I did mine recent Don.
I'd get the parts on my own, personally. If you get a PI converter, you can keep the 6.0 flexplate and skip the spacer stuff as well. I used the new shift cable bracket, and ended up throwing out the dipstick tube that I got from SE (wouldn't fit my truck) and going with a Lokar flex tube (plus its polished alum. for that extra bling). I ordered the wiring and plug adaptors directly from speartech (which you need for the 2nd VSS on the latest 80E design) and ran my own -6AN tranny cooler lines with a derale AN cooler (plus the hard line to AN converters). I used the tranny cross member from an 03 2500 HD (use the same year as the truck and match the drive). Because I switched from AWD to 2WD, I countersunk and welded some grade 8 bolts to in the frame and bolted the crossmember straight up. I didn't need anything else (except the 80E segment for the PCM which I got from a friend and copied into my custom os with EFI Live).
Old Aug 15, 2007 | 08:05 AM
Slowhawk's Avatar
LS1Tech Sponsor
Thanks. My tranny guy is looking into the swap now.The programming is no problem since I already have an Avalanche 6.0/4L80 tranny file that works.
Just looking for the easiest,fastest way for the swap.I like doing motors ect but hate Auto tranny's.
Old Aug 15, 2007 | 09:30 AM
I AM A MOTHERF*CKER
Let me know how it all works man. You know, just in case I need to do it to my wife's Av for some *cough* twin turbo *cough* reason when she's on vacation or something
Old Aug 15, 2007 | 10:21 AM
Slowhawk's Avatar
LS1Tech Sponsor
I told the wife we need it for towing
She didn't notice the new 6.0 iron block sitting in the corner
Old Aug 15, 2007 | 11:45 AM
I AM A MOTHERF*CKER
I'll have to try that one
Old Oct 3, 2007 | 05:07 PM
brody90's Avatar
think i could get the 6.0/4l80 computer file that you have?
Old Oct 3, 2007 | 05:15 PM
tarinitup's Avatar
9 Second Truck Club
a member by the name of doublenot was selling a complete kit a few months ago. I decided to go flt instead of his speed engineering kit but his price was 2800 for everything.
Blwn99x
Mar 24, 2023 11:14 AM
SloSVO
Nov 22, 2020 07:34 PM
blownss27
Aug 14, 2020 08:27 AM
Silver8ado
Sep 30, 2015 11:42 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
