4L70E shift problems
Old Jul 8, 2015 | 04:48 PM
ferrellrooster's Avatar
Default 4L70E shift problems
Hello all,
I have had several transmission problems in my years but this one beats all. I have 2 trucks. 2001 GMC 1500 5.3 with the 4L60E, and a 2007 silverado MAX 1500 with the 6.0 and the 4L70E.
Problem #1.
The 4L60E clutches went out a few times. The obvious was it wouldn't go anywhere..lol and tac out. Had it rebuilt. Has about 10,000 miles on it now. Runs good, no slip, up to the point trans temp hits 195. Once temp hits 195 it starts to slip. You can watch the tac start jumping up a little and also feel it. And know when you throttle its slipping. But when it cools back down you can floor it in all gears and its fine up until it warms back up.
Problem #2.
2007 Silverado MAX 4L70E.
This one I have one idea for the problem but have not attempted to do anything yet as I will explain.
I can floor this truck and boil the tires off of it, then when shift to 2nd....there is no second. Just tacs out. I can let off and third will catch and I have third. I can ride third gear half throttle so it wont down shift to second because there is no second up until I run out of road. I mean it will flat out fly over 115 easy....but wont shift into 4th or overdrive.
So.....1st but no 2nd hookup, shifts to second but tacs out not catching and 3rd but wont even shift into 4th.
I was thinking it was not forward clutch because I have such a strong 1 and 3rd. But can not explain a total slipping 2nd. Bringing me to question
a. if it may be the a&b solenoid?
b. the piston accumulator?
I have read that the pistons X 2, 1-2 and 3-4, are pinned plastic and fail because of leakage and people going to the aluminum pin less. Would it cause no shift? or a slipping 2nd? I dont know. Would the a/b solenoid be the culprit? I dont know without just changing parts.
But would really just want to know if I am barking up the wrong tree all together.
Worst case scenario I will have to pull it and bring it to get total rebuild. I was just trying, like everyone else, to avoid the pull. Only reason once again was because I have questions about having a strong 1st and 3rd like nothing is wrong. Unlike every other trans I have burnt up that just slips in every gear and eventually just quits pulling. And I have probably burnt clutches in close to 35 or more. But I have never had this kind of problem on either one truck that are going on right now.
Thanks for any input.
Respectfully,
Rooster
Old Jul 10, 2015 | 10:14 AM
well I guess no one has had any of these issues. I ordered 2 billet pinned piston accumulator because I read that the pinless will not work with a tuner.
Old Jul 12, 2015 | 12:26 PM
1987cut's Avatar
How did your trans workout? I'm installing a superior trans shift correction kit along with the pinless accumulators as I'm writing this. I was curious if the stiffer springs could be installed with these Pistons?
Old Jul 12, 2015 | 06:11 PM
James B.'s Avatar
The band is used for both second and fourth. There's a fairly easy way to tell if the band is smoked in a 60/65/70. Get the truck in the air enough to get under it, make sure it's in park and let the engine idle. Crawl under and use a pry bar to apply force to the servo cover on the passenger side. (you may need to remove a heat shield to get to it). The engine should bog noticeably when you do this. If that has no effect it could mean the band is burnt up. If it does bog you can focus on a hydraulics problem.
Old Jul 13, 2015 | 09:45 AM
Now that is a good trick. I am to far in, taking the valvebody off to try it. But dang.....that is definitely one of those things that only come from experience. Thanks for sharing.
I thought I could get pan off without dropping exhaust but that was a big hell no. Drained most all the fluid. My 2001 is all 15mm exhaust bolts. This 2007 has 2 different sizes 15 & 17mm. I broke/split a deep well trying to get it off even with heat, so I have to go to store today after work to get some impact quality 6 points. Should know something in a day or so after I put the new accumulators in.
After knowing this trick you shared I feel like Im working backwards. lol
Old Jul 13, 2015 | 09:53 AM
quick question. if the band is burnt wouldnt it still shift into 4th and slip?
It is shifting to 2nd but just tachs out, shifts to 3rd runs great, but does not shift at all to 4th. 1st is strong, 3rd is strong and tight.
Old Mar 6, 2025 | 09:31 AM
eponce90's Avatar
Was the issue ever found? I'm having the exact same problem.
Old Mar 6, 2025 | 03:22 PM
James B.'s Avatar
Old thread but still useful...
A missing band engagement in a 700R4/4L60-E/4L65-E/4L70-E/4L75-E (same geartrain architecture) will have no second (1.625:1) or fourth (0.696:1) gear ratios.
How this feels driving depends on throttle position:
Light throttle - will feel like it hangs in first for too long with too much RPM before shifting to third. Fourth never comes.
Moderate throttle - will hold in first, RPM increases far beyond normal, may hit rev limiter until speed vs.throttle position is enough to command third. Once in third if more pedal is applied to invoke a downshift to what should be second, it will freewheel and hit the rev limiter feeling like it's in neutral. As that point it's actually in first gear with no overrun engagement, so the output is spinning faster than the input, which feel like neutral.
Full throttle - Will with the rev limiter at the top of first and not upshift at all until you let off the throttle.
It should be pointed out that it is possible to limp the transmission home by driving with very light throttle, but use manual gear selection to avoid the "missing" ratios because you have to imagine the valve body is probably still trying to apply that servos (in this case) and could be causing metal-to-metal contact in the absence of friction material. In my experience, the band almost never gets used up before the 3/4 clutch pack. What's more likely is that the pin retainer on the band broke off or it broke at the servo end, or there is a servo problem where it's either cracked or the o-ring damaged.
You can determine if is a physical problem (broken band/burnt clutch material) or a hydraulic problem (valve body gasket blowout/shift solenoid/cracked servo or servo sealing ring/etc.) by lifting the rear wheels of the ground, putting the truck in the air, running it in manual 1st. gear, and then using a prybar to apply pressure to the servo cap (passenger side) to press it in. If you have a good band then you'll hear the engine load up as the band engagement in manual first with the overrun clutches engage will create a mechanical binding situation slowing the rear wheels. This is a safe test to perform - the torque converter is not locked and it is impossible to stall the engine doing this. If pushing that servo cover inward does nothing then you've got a bad band. If it binds then you can focus on valve body hydraulics and electronics.
Also, all of this can be symptomatic of an incompetent tuner. They are out there and they do cause stuff like this. So, some backstory leading up to the condition is always helpful.
blownss27
Aug 14, 2020 08:27 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Texas5.3_1251
Mar 5, 2016 08:10 PM
jtphelps289
Sep 29, 2015 12:00 PM
mayko
Sep 7, 2015 12:24 PM
