4L65E Questions!?
Old Jul 4, 2012 | 04:59 PM
Marlow21's Avatar
Registered User
Default 4L65E Questions!?
I have a complete stock 4L65E Trans but I've got future plans for an STS rear mount to go on the truck. I'm lookin at puttin a Transgo Shift Kit and the Corvette servo in but idk what else maybe needed for it to hold up. Any ideas? Also how many washers should be used with the shift kit? The truck is gettin a Wideband and Custom Tune from a local Performance shop using HPT. Thanks for all the help
Old Jul 5, 2012 | 10:13 AM
5.3 GMC's Avatar
I haven't found a 60 that will hold up no matter what performance mods are done to it. Of course I'm very hard on stuff. Idk the whole difference in the 60 and 65 but from what I understand the 65 isn't much if any stronger. But I'm not making that much power and I have broke 4 60s that are supposed to be 700+ HP rated. So is say u might wanna think about a 80.
Old Jul 5, 2012 | 10:54 AM
nonnieselman's Avatar
No washers,
If you plan on beating on the truck, id also start lookin for an 80E. Much cheaper in the long run!
Old Jul 5, 2012 | 12:18 PM
Marlow21's Avatar
Registered User
Do they 80's bolt straight on though without major modification?
Old Jul 5, 2012 | 12:25 PM
if your 2wd its a easy swap.. just a crossmember modification and a yoke for the driveshaft.
Marlow21's Avatar
Registered User
As long as its a 14 bolt it shouldn't matter should it?
Old Jul 5, 2012 | 12:46 PM
14 bolt rear axle?
lil more info on the truck will help a ton!
Old Jul 5, 2012 | 12:58 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You have to add a second speed sensor, re-pin the 80E connector (I think its 2 pins that get swaped), have the ECU flashed accordingly, Modify the trans cross member. I believe the mounting point is around 5-6 inches rear ward, and the over all length of an 80E is around 5/8 of an inch shorter.
Old Jul 5, 2012 | 01:54 PM
Marlow21's Avatar
Registered User
The truck is 4wd sorry about not mentioning it earlier. The truck is my dd so idk about the swap I might just add the shift kit and servo and leave the boost down around 3-5psi lol
