4l65e?
Old Mar 19, 2009 | 07:34 PM
00blackz71's Avatar
Default 4l65e?
Will a 2006 4l65e from a GTO work in a 2002 chevy truck?
Old Mar 19, 2009 | 08:20 PM
ForcedTQ's Avatar
If your truck is a 2wd, all you might need to do is swap the rear trans housing, transmission fluid dipstick? possibly. If your truck is 4wd, you will need to have the rear output shaft changed as well which requires complete dis-assembly of the transmission to change out.
Old Mar 19, 2009 | 08:32 PM
00blackz71's Avatar
It is a 2wd.
Old Mar 20, 2009 | 08:54 PM
00blackz71's Avatar
So the housing will have to be changed but the output shaft will work?
Old Mar 20, 2009 | 09:04 PM
ForcedTQ's Avatar
That was one point I am not sure on, if the spline count, diameter, and length of the output shaft are the same you'll be fine. Compare it with the one in your truck.
Old Mar 20, 2009 | 09:07 PM
00blackz71's Avatar
I don't have the 4l65e yet. Looking at buying one I found and wanted to make sure it will work before I buy it.
Old Mar 20, 2009 | 09:13 PM
ForcedTQ's Avatar
Lightbulb
Ask them to take a few good quality pictures with a measuring tape for you so you can make your "educated" decision. Then have them sent to you. That should do it.
SS94S10
Jan 3, 2019 01:57 PM
chopperloco
Sep 28, 2015 08:40 AM
g6t6o
Sep 26, 2015 10:57 AM
blownss27
Aug 14, 2015 03:31 PM
maxspeed05V
Aug 12, 2015 06:29 PM
