4L65 differences, performance, etc...
Old Feb 28, 2005 | 11:05 AM
Weedo's Avatar
Default 4L65 differences, performance, etc...
With the STS kit (5-9psi), I'm pretty sure my 4L65 will fail eventually. I know FLP makes a built 4L65. How different is the stock 4L65 from the stock 4L60? Is it stronger?
Here's the issue... I want to put in a 2500 or so Stall. The cost to put in the Stall is about 6 hours. Or, I could go with a built trans that would include a shift kit and have the stall put in all for about 6-7 hours. So if I get a Stall now, then fry the Trans, I'll be out the extra 6 hours of labor.
Do I bite the bullet and do the Trans now, or hope that I won't smoke it?
Any other choices besides the FLP for $2850??
Thanks for any help/advice!!
Old Feb 28, 2005 | 11:16 AM
quicksilverado's Avatar
Teamtripp.com Several truck guys have their tranny. A good bit cheaper.
Old Feb 28, 2005 | 11:52 AM
Weedo's Avatar
I've heard the 4L65 is stonger than the 60, is that true? If so, i'm wondering if I really will need a built trans or not.?.?
Old Feb 28, 2005 | 12:01 PM
The 65E is stronger than the 60E, but still has its weaknesses. The 65E has a 5 pinion planetary gear(that a built 60-E will have) instead of 4 like a stock 60E, it has a hardened sun gear, and hardened input and output shafts. I believe those are the main differences between the 60-E and the 65-E. It basically strengthens a few of the weak points.
Old Feb 28, 2005 | 08:31 PM
Weedo's Avatar
OOOHHH! Found this link, great info on the differences...
http://www.superchevy-web.com/tech/0311sc_4l65e/
Old Mar 1, 2005 | 08:06 PM
agreif's Avatar
Thanks for that link.
Old Jun 23, 2005 | 10:05 PM
budhayes3's Avatar
PT's Slowest Truck
That's some real good info there!
GXPJAY
Feb 13, 2022 08:15 AM
Noah Burns
Sep 7, 2015 05:50 PM
Denali08
Aug 9, 2015 04:34 PM
cbhedrick
Jul 20, 2015 10:12 PM
Deceptarado
Jul 8, 2015 05:24 PM
