4L60E w/yank 3600 problem
Old Nov 30, 2010 | 02:09 PM
wyatt_450's Avatar
Default 4L60E w/yank 3600 problem
Alittle over a year ago, I put in a yank 3600 stall and trans go shift kit in my truck. Last winter when i put it in, everything ran perfect, shifted great. Then one night, I pulled up to a buddy to shoot the ****, then when I pulled away the trans was slipping horrible. It would only pull normal if I manually shifted it, but the TC wouldnt lock up. All I would have to do to make the truck shift right again would be to put it in park and turn it off for a minute or so. Then it would be good to go. It only did this once or twice last winter, and as the weather warmed up the problem disappeared.
I went all summer, up till about a month ago, without any trouble. Now as the weather is turning cooler here it has started acting up again, but it has already has acted up a few times. Seems to be worse than last year.
The truck shifts perfect and tc locks up perfect otherwise. I am running Napa trans fluid and put a new filter in when i did the swap. I also thought i washed the **** outta the valve body before reassembly. I have prolly put 8,000 miles on it since the install.
Any ideas??
Old Nov 30, 2010 | 02:18 PM
BlackGMC's Avatar
Resident Retard
when it does it, check to see what code it is throwing, then disable that test with tuning software... My truck did that when i put my verter in... It would only do it every once in awhile... I disabled the test and i have never had that problem again... I forgot the test you need to disable, but pull you codes...
Old Nov 30, 2010 | 02:28 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Probably a tuning issue. If you have EFI Live or HPTuners, you're all set. If not, get a tune by a reputable sponsor.
https://www.performancetrucks.net/fo...5&postcount=17
https://www.performancetrucks.net/fo...8&postcount=19
https://www.performancetrucks.net/fo...8&postcount=27
zblee
Nov 11, 2015 12:41 AM
94f150
Sep 13, 2015 06:39 PM
Pimpinpete
Sep 8, 2015 07:39 PM
screaminian47
Sep 7, 2015 08:20 PM
mayko
Sep 7, 2015 12:24 PM
