4l60e transmission has no over drive
Old Jan 4, 2011 | 09:02 PM
pittster's Avatar
Registered User
Exclamation 4l60e transmission has no over drive
I have a 93 chevy k1500 and i did an oil change on the transmission and now i have no over drive, i had OD be for the fluid change ,all i did was change the filter and new fluid ,any suggestions on what it might be?
Old Jan 4, 2011 | 10:36 PM
dmelvin's Avatar
Did you put too much fluid in? I did that once, I still had overdrive, however, the transmission did run really differently.
Old Jan 5, 2011 | 03:16 PM
pittster's Avatar
Registered User
nope fluid is dead on where it needs to be
Old Jan 5, 2011 | 06:03 PM
Vince B's Avatar
Are you sure that you have 1st gear? If I had to guess you unplugged or damaged the 1-2 solenoid when you pulled or installed the pan. I would drop the pan and take a look at the two solenoids in the rear area of the valve body. If you had an issue pulling the pan due to exhaust clearance then you should find your issue.
Old Jan 6, 2011 | 12:20 PM
pittster's Avatar
Registered User
yeah i have 1st gear and it shifts fine jus when i get up to speed the od will not kick in
Old Jan 7, 2011 | 10:33 AM
Johnny@Xtreme_Trans's Avatar
FormerVendor
Check the solenoids at the plastic snout for cracks. Thecan break on the removal or installation of the pan
Old Jan 7, 2011 | 02:40 PM
andrew383's Avatar
traveling mod
What trans fluid did you refill with???
zblee
63
Jun 10, 2023 01:25 PM
XL7
May 5, 2022 01:48 PM
meadows
13
Aug 25, 2015 08:29 PM
Ferocity02
Aug 7, 2015 08:50 PM
SleeperGMC
Jul 29, 2015 10:22 AM
