4l60e to th400 wiring question
Old Apr 21, 2014 | 09:13 PM
silverado.408's Avatar
Default 4l60e to th400 wiring question
In the middle of my th400 swap. I tried to start the truck but no go. I think its the Neutral Safety switch. Does anybody know how to by pass it. I know Fbody's do it all the time. Does anybody know what to do. Thanks
Old Apr 22, 2014 | 02:22 PM
Ranger6202's Avatar
Do you have access to efi live or hp tunes? You're gonna have to shut off a lot of DTC's to run it right. Or get a segment swap to Manual trans. My 6.0 is running a th400 and all i have is manual segment....no wiring changes needed. As for YOUR p/n wire question. You'll want pin 34 on your blue connector. If i remember right you want ignition hot returned on this wire, if not, unhook it, but i'm fairly sure its IGN HOT. You're also gonna want a VSS signal or else you're engine will die if not stumble when rolling to a stop....trust me on this one.
Old Apr 22, 2014 | 05:07 PM
Ok my tuner Is PAT G I have a fresh tune in the ECM with everything needed to be off off. You confused the crap out of me with the wire stuff. Can you explain it preschool style please. I'm not that smart.
Old Apr 22, 2014 | 06:18 PM
slowswb's Avatar
take the safety Neutral Safety switch off your 4l60e and plug it and make sure it in Neutral on the gear on dash that that how you need to get a it work for a th400.
Old Apr 22, 2014 | 06:26 PM
Got it will do thanks.
Old Apr 22, 2014 | 07:00 PM
That worked thanks a ton.
Old Sep 21, 2014 | 09:21 PM
dirt track racer 81's Avatar
Hows this working out with the p/n switch set in neutral? Mine is left in park, truck runs and drives fine, but I have a hard time starting it. It'll just keep cranking, or it'll backfire, but generally if i try cranking it again after it backfires it'll start right up...
ferrellrooster
Mar 6, 2025 03:22 PM
Blackrat48
Aug 16, 2015 11:56 AM
USMCvet0311
Aug 1, 2015 07:45 AM
