4L60E build tips/tricks, parts list
Old Nov 15, 2012 | 01:05 AM
silverz28camaro's Avatar
Default 4L60E build tips/tricks, parts list
I would like to post up my 4l60E build list I have been running in mt Nitrous 1988 Dodge Ram 400+ rwhp running high 12's
This transmission has been getting a workout since the 3600 stall was installed in late 2010..I daily drive this truck so its very important to get a build to hold, last and be streetable
First of Thanks to Dave at YANK converters for talking me into the SSTB3600, I have driven this converter nearly everyday and have towed 5,500lbs with the 3.90 gears to match
While towing with this converter is NOT recommended I have done it several times..I programmed my computer to lockup the converter in 3rd at 30 mph and hold it in the "3" position...at speeds 30-55 this works fine...At speeds above 55 mph its in lockup 4th gear and pulls the load, This might not be acceptable in a smaller cubed motor such as a 4.8 5.3 with a cam. My 1998 LS1 is internally stock with bolt-ons only and has great lowend tq
Old Nov 15, 2012 | 01:14 AM
Parts list for this build
-beast sunshell
-wide rear sungear bushing
-new reverse input drum
-alto carbonite standard width 2-4 band
-borg warner dual cage sprag
-wider rear stator support bushing teflon coated
-billet forward piston
-sonnax HD sleeve kit for the input drum
-Raybestos 3-4 z-pack, with 2 extra clutches, .125 backing plate, .060 snapring, clearance set at .050 with longer boost springs for 6,500 + rpm
-high rpm pump spring(important for cammed motors)
-sonnax .490 boost valve
-corvette servo
-billet 4th gear( for towing in OD!!!!)
-transgo separator plate..feed holes drilled...2nd .093 3rd .115-.120 4th .120 lockup feed.055-.070
-aluminum 2nd acc piston
-aluminum forward piston
-slightly stiffer 2nd gear acc spring(DON"T go to stiff)
-servo release checkvalve
-HD 2-3 shift valve (requires valve body drilled)
-NEW EPC solenoid for extra insurance and new electronics depending on budget
-early style forward return cage(stiffer and helps reduce high rpm drag and forward harsh engagement)
-Code 1870 TCC valve fix(converts TCC PWM to full pressure on/off type)
Old Nov 15, 2012 | 01:15 AM
And of coarse new overhaul kit that includes gaskets seals clutches steels
Old Nov 15, 2012 | 01:19 AM
Computer tuning Is KEY, With this setup I have my requested shift times at .15 for the 1-2 shift .12 for the 2-3 and .15 for the 3-4, all trans pressures are left stock in the tables.
Lockup in 4th comes in at 40 mph and out at 36 mph..In manual "3rd" lockup comes in at 31mph, this is the only reason I can tow with this large of converter without damage
Old Nov 15, 2012 | 01:20 AM
If I forgot anything I will update the list
Old Nov 15, 2012 | 01:21 AM
IMO, this build is very good for 400-450 rwhp in a truck.....anything more and I would highly recommend billet output and OEM GM 5 pinion front and rear planetaries...STAY AWAY FROM CHEAP 5 pinions
Old Nov 15, 2012 | 01:27 AM
Some vids of the trans in work
with 75 shot and Yank sstb 3600
This was BEFORE the YANK converter and nitrous
5.3lSilverado
25
Aug 29, 2016 12:48 AM
5.3Caprice
Nov 7, 2015 08:56 PM
USMCvet0311
Aug 14, 2015 10:28 PM
Aboss
Jul 9, 2015 10:28 AM
Mzay
Jul 6, 2015 11:05 PM
