4l60e build with $100 core...
Old Oct 12, 2015 | 12:54 AM
  #111
Wolftrk99's Avatar
Ok got the valve body drilled for the the 2-3 shift valve and the separator plate modified.... I went ahead and used the factory plate that came with my valve body... Just need to get the surface rust off of it before i install it, decided to go that route, so i either have the transgo plate as a backup or can return it and get some money back from it......
1/8" hole drilled through valve body for the hd2-3 shift valve as per sonnax instructions.....
Separator plate marked and drilled......
Old Oct 12, 2015 | 12:55 AM
  #112
Wolftrk99's Avatar
Still need to dril and block the pwm feed hole
Old Oct 12, 2015 | 08:56 PM
  #113
Wolftrk99's Avatar
Never realized a damned 1/16 drill bit would be so hard to find, that isnt already broken!!!! Oh well, snappy will be there tomorrow!!!
Old Oct 13, 2015 | 12:12 AM
  #114
Wolftrk99's Avatar
Well after a 12:30am walmart run for a $15 set of drill bits..... My pwm feed hole is plugged, gonna see if i cant use a real hammer and a vise at work to peen it a bit flatter tomorrow...
Old Oct 13, 2015 | 08:23 PM
  #115
Wolftrk99's Avatar
Pwm plug peened... Amazing what two taps with an 8oz ball peen will do to a 1/16" piece of aluminum...
Separator plate post rust removal....
Old Oct 13, 2015 | 08:52 PM
  #116
tgui's Avatar
Wow, that cleaned up nicely!!
What did you use to plug the pwm hole?
You almost done?
Old Oct 13, 2015 | 09:06 PM
  #117
Wolftrk99's Avatar
Sonnax kit has plugs for the pwm hole included... Took my die grinder with a 3m disc on it at about 1/4 throttle, just barely grazed it til the rust came off.... Ill probably hit it again with trans fluid soaked steel wool before it goes in....
Theoretically....yes, however.... Had an offer brought to my attention I would be stoooopid to pass up, so.....im goin back with 5 pinion GM planetaries
Old Oct 13, 2015 | 09:10 PM
  #118
tgui's Avatar
Sweet deal! Not that Chinese ****.
Old Oct 13, 2015 | 09:14 PM
  #119
Wolftrk99's Avatar
At this point im about ready to get this together get my tc and get it in so i can get my headers and cats on at the same time, so i can get her retuned.... And im really curious as to what is so special about this trans thats in the truck!!! Kicking myself for ever sending them the core back.... Coulda saved myself some $$$, oh well live and learn...... Debating if i wanna pull the input sprag back aprt and spend another $50 on the bw dual cage....
Old Oct 13, 2015 | 09:27 PM
  #120
tgui's Avatar
If you have the time and $$ bw part might be a good thing. You're doing 5 pinion after all!
Live and learn?! Yeah, I do that all the time I kinda wish I got a newer 4l80e. Then again I've learned a ton and that's what I wanted.
