4l60e bolt to a 6.0L
Old May 30, 2008 | 11:54 AM
GMCDee's Avatar
Default 4l60e bolt to a 6.0L
Im swapping motors from a 4.8 to a 6.0 will my 4l60e bolt up to my 6.0l.
Old May 30, 2008 | 12:06 PM
OnyxSilveradoSS's Avatar
yes it will
Old May 30, 2008 | 12:13 PM
thunder550's Avatar
High on diesel fumes
If the 6.0L was from a 4L80E truck you'll have to use the flexplate from the 4.8 and make sure that you pull the flexplate spacer off the 6.0. If it had a 4L60/65 bolted up you'll be fine and it will swap directly.
What year and model truck was the 6.0 from?
Old May 30, 2008 | 12:54 PM
SpoolinChevy's Avatar
-stupid. I learned the hard way, lol. If you're not sure, just put your converter on the flexplate and make sure the bolt holes line up. I believe the one for the 4L80e will have bolt holes that are too spread out, so it's easy to notice which one fits.
Old May 30, 2008 | 01:26 PM
GMCDee's Avatar
2000 gmc 2500 is where im getting the trans.
Old May 30, 2008 | 01:58 PM
GMCDee's Avatar
Im going to be running around 12 psi and hope for around 600hp at the wheels so im hoping my stage 2 flt will hold, i just ordered it when i came across this 6.0. Im kinda new at this so i dont want to cut any corners.
Old May 30, 2008 | 02:40 PM
gao8302's Avatar
to cut any corners.
The FLT lvl5 would have been a better choice if you plan on making that much power. They rate the lvl 5 to 550 so....
Old May 31, 2008 | 03:34 AM
bpowell688's Avatar
Old May 31, 2008 | 04:15 AM
viciousknid's Avatar
Where's the Beef?
If your using a stock 4l60e your already cutting corners. It might last 2 weeks with that much hp.
Old May 31, 2008 | 12:59 PM
thunder550's Avatar
You'll have to swap flexplates and remove the spacer.
