4L60E to 4L80E Wiring Swap
Old Mar 17, 2008 | 09:45 AM
Derek @ EDO's Avatar
FormerVendor
Nice! I know what ill be doing!
Old Mar 17, 2008 | 09:18 PM
BigKID's Avatar
That is the same thing I am doing. I was just going to cut the white and brown wires at the connector, swap and splice back together. How difficult is it to remove the wires from the trans connector and switch them that way? I don't want to screw up the connector.
As for the additional VSS connector, I went to the local Pick-N-Pull and cut one off another truck for $1. Dealer wanted $39 for it new.
Old Mar 17, 2008 | 09:42 PM
DrX's Avatar
DrX
That will work. I haven't looked at the connector yet. It is a 20-way Micropak 100W series. http://connectors2.delphi.com/dcsgdm...structions.pdf
Old Mar 18, 2008 | 09:33 AM
nonnieselman's Avatar
its very easy to pull the wires out and move them.. my buddy did it for me while I was puttin the shift kit in... if he can do it anybody can! haha..
just take your time.
also when pushing the pins in the PCM connector remove the colored covers for a less stressful install..
Old Mar 18, 2008 | 09:36 AM
if anybody needs some help feel free to PM me. ill give you my number and can walk you thru it.
Old Mar 18, 2008 | 09:37 AM
DrX's Avatar
DrX
Did you swap the pins at the trans end or did you do everything at the PCM end?
BTW...The PCM connectors are also Micropaks.
Old Mar 21, 2008 | 10:25 AM
Flaco's Avatar
8 Second Club
anybody done this on a 03 plus, with the green connector?????
Old Mar 21, 2008 | 11:11 AM
DrX's Avatar
DrX
Looks like it will be the same.
I wrote it up for quick reference:
Old Mar 21, 2008 | 11:27 AM
FormerVendor
Nice writeup, I made a .JPG copy for quick board reference.
Old Mar 21, 2008 | 11:44 AM
DrX's Avatar
DrX
