4L60E to 4L80E Wiring Swap
Old 07-07-2011, 11:35 PM
  #111
sleeperlqx's Avatar
Originally Posted by black04
Anyone done the method of running the 4L80e on a 4L60e tune? I've seen a few posts on tech but nothing detailed. It had something to do with wiring a relay into the harness to switch polarity on one of the shift solenoids.
BINGO. Been searching for hours, and that guy on Tech needs to give us a schematic on the relay wiring. From my understanding, you just use the rear vss sensor only, and some how add 2 relays to the current 60e wiring, and the 60e segment will run the 80e trans without a segment swap, and missing with the pcm up under the hood for the iss sensor.
I also read it can even control it better as far as converter locking and unlocking methods as well.
This is the route I am going to go with as well! Hope some sheds some insight.
sleeperlqx is offline
Old 07-07-2011, 11:52 PM
  #112
black04's Avatar
PM me if you'd like to know. I paid the guy 20 bucks.
black04 is offline
Old 07-08-2011, 01:19 AM
  #113
sleeperlqx's Avatar
Pm sent
Old 07-08-2011, 01:16 PM
  #114
N20GMC's Avatar
I know a guy that owns a trans shop in texas that does the electrical swap also. PM if anyone needs his contact info.
N20GMC is offline
Old 10-24-2011, 06:59 PM
  #115
11 Second Club
Phantom's Avatar
Let me see if I got this right. Instead of using the vss, I'll now use the ISS and run the wires to pins 22 and 23? Wiring diagrams confuse me
Phantom is offline
Old 10-24-2011, 07:10 PM
  #116
formerly lamborado (1-12-2012)
BOTLFED_AWD's Avatar
fwiw i had to use both. the plug on the tailshaft and the plug up by the prndl, which is the vss, and wired it to pin 22 and 23.
BOTLFED_AWD is offline
Old 10-24-2011, 07:12 PM
  #117
11 Second Club
Phantom's Avatar
Thanks man. It would probably make more sense to me if I had my trans sittin in front of me, but I don't so I have no reference. It's driving me in-f'n-sane
Phantom is offline
Old 10-24-2011, 07:19 PM
  #118
when you get it, the plugs are identical, the plug closest to the front goes to the pcm, if not itll be shifting all funny, dont ask me how i know
Old 12-17-2011, 01:05 PM
  #119
Registered User
Shawn Christensen's Avatar
I used this wire swap on my 97 chevy truck and now when i get up to 6mph the truck cuts out and dies. not sure what the problem is. Any ideas?
Shawn Christensen is offline
Old 12-17-2011, 01:09 PM
  #120
Custm2500's Rude Friend
1FastBrick's Avatar
you have to change the transmission file calibration for the 4L80E.
Look in the other thread you just started.
1FastBrick is offline
Quick Reply: 4L60E to 4L80E Wiring Swap
