4L60e 2WD removal with pics
Old Apr 3, 2012 | 11:25 PM
  #21
06sierra5.3's Avatar
sweet baby Jesus this thing is finally going back together. Waiting on my converter, then need a re-tune. will be posting pics soon. Hopefull the last few little parts, accumulators pistons and such show up this week so I can assemble this weekend. Pump and valve body are rebuilt and ready to go.
Old Jan 8, 2014 | 08:34 PM
  #22
hsiriyob's Avatar
great thread ill be using this this weekend thanks
Old Aug 5, 2014 | 11:39 PM
  #23
AleBarMx's Avatar
Registered User
Hi 06Sierra, before anything let me congratulate you for such a great explanation on how to take the transmission down! THANK YOU!!, and great pics as well!!
I have a veeery little problem, somehow i lost the little bolt that holds the line bracket on drivers side.. the 8 mm hex one... the one showing on your #14th step...
and i havent be able to put a new one back, because cant find the right one! no one fits! if you are so kind to please let me know what fricking size the thread is and if it is standard or milimetric tread, so i can go buy the right one for once!
The lines are loose and they rattle when riding, is not the noise that worries me, is the fact that they may brake! and yea well the rattling noise is annoying!
THANK YOU VERY MUCH in advance, i hope you can help me out with this little one.
Best Regards
Ale Bar.
Old Jul 6, 2017 | 06:44 AM
  #24
madmann26's Avatar
I fkn hate photobucket.
Old Jul 22, 2017 | 11:05 AM
  #25
rojeho's Avatar
Is there any sort of trick for mating the new trans back to the engine? And to reattach the torque converter to the flywheel, do I rotate the engine to get the hole in the flywheel in a good spot and then turn the TC from the bottom inspection hole?
Old Jul 22, 2017 | 04:54 PM
  #26
madmann26's Avatar
Use the cavity where the starter is. You'll have to spin the engine so the TC/flexplate hole is accessible.
Reach up into the starter cavity and spin the TC. Thread the bolt, torque to 44ft lbs. Repeat 2x.
Old Jul 23, 2017 | 05:22 AM
  #27
rojeho's Avatar
Thank you very much!
Old Aug 6, 2017 | 08:36 PM
  #28
Mark Johnson's Avatar
How much does a 4L60e weigh? Drained, of course................
Old Aug 6, 2017 | 09:07 PM
  #29
zeake's Avatar
Too much 260lbs
Old Aug 7, 2017 | 04:43 AM
  #30
madmann26's Avatar
Originally Posted by zeake
Too much 260lbs
160 dry weight.
typo?
I was able to lift it via the BH and tailshaft to set it on the jack. :/
