4L60E= Dead again! 2 days old
I don't know at this point I'm more concerened about just getting my truck back and being able to do what I need to do.
I do know I'll put more press on getting the parts for the 80E swap now. Only have the spacer and flexplate.
Very true it's just a matter of luck, it could be something from the supplier was bad and it went into my trans. I'll find out once I get it back. I do trust the guy and his work but you have to remember that it is not the one guy doing the work he has several employees and they could of made a mistake during the build.
I treated this trans just like the others from the jump and this one just had a bad part or something. I'm frustrated but not pissed, I do understand that things do happen.
Not to put FLT or Performabuilt down but they are not the only transmission shops in the USA I know their stuff fails also. Some have better luck then others.
Use the correct tranny for your application. a 60e should have never been applied to a truck period. but we got to blame GM for that.
you say something from supplier was bad?? BS. Its the shop, they had 6 times to fix it. Are you going to allow them to have 6 more tries at it? I dont think so... Those sponsors are not the only trans builders, true that. But they have experience that most dont have. And even still, I bet you can blow one of their trannies in a vehicle that is heavy enuff, with enuff power.
This is the forth time that the shop has rebuilt it, the first time I supplied the TC and it went and wiped out the trans 6 months after the rebuild and it lasted 13 months. I give the doubt of the fact before I give someone hell.
First time it was rebuilt at the dealership under warranty, second one was built by him with my supplied converter. It was a Fuddle converter. The one last week was cause of the planetary going and whipping out the rest of the trans and today is unknown as of now.
I agree that the 60E is not the best choice for the trucks but it serves it purpose for the average guy just hauling a toy or a load of lumber it was not made in the masses for racing or adding additional power.
You can get a converter from PI that has a 60e bolt pattern on front that will mate to the 80e, Thats what i did.
You need the VSS connector from efi connections.
The crossmember is easy to mod.
You need the 80e dipstick, and new trans lines, just one actually.
And you need a shorter driveshaft, i used the yoke off my stock shaft and had a 3'' steel shaft made, works great.
Kysilverados thread is what helped me most for the info.
Correct, there are lots of builders out there, if you or anyone plans to use a 60e in these heavy trucks, I'd have Vince B or Rossler build one,
I'm guessing Vince B built my 60E, due to the VB stamped after FLTLVL5 on the trans case. That thing took a beating. It's too bad the converter took it out because I would have really liked to know how far I could have pushed it in my big turd. Now someone at FLT is rebuilding it. Hope they can build it as good as Vince did...
Sonnax makes a HD 2-3 shift valve that supports the forward sprag when in the shifter "3" position. Get this as well and race in 3 to support the sprag
