315 tire on stock rear end?
Old Sep 26, 2012 | 01:54 PM
qwk_snd's Avatar
Default 315 tire on stock rear end?
I'm wanting to pick up a set of 315/45/16 radials for my truck and was just wondering if they'd fit up under it and not stick out a million miles or rub my frame with my stock width rear end?
Old Sep 26, 2012 | 02:07 PM
jvoisel's Avatar
Depends on the rims.
Old Sep 26, 2012 | 02:13 PM
qwk_snd's Avatar
What offset should I buy to bring them as close in to the frame as possible so that they don't stick out a ton?
Old Sep 26, 2012 | 03:24 PM
xx_ED_xx's Avatar
I got 315 35 20 on the back of mine
Old Sep 26, 2012 | 03:31 PM
qwk_snd's Avatar
What offset are your wheels? I don't want them poking out the side... lol
Old Sep 27, 2012 | 05:20 AM
blown02408's Avatar
02 w/ lowest mileage 2800
At least 6.5" and up to 7" backspacing.
Old Sep 27, 2012 | 08:38 AM
BigKID's Avatar
I'll add that with a 16" wheel, 6" of backspace is all you can put on stock disk brakes before contact with the banjo bolt on the caliper. If you want the wheel to tuck, no more than 3" of front space. So the widest 16" wheel you could use and be inside the fender would be a 16x9 with 6" bs. This applies to the wheel only. Tires add extra width so adjust accordingly.
Old Sep 27, 2012 | 02:55 PM
qwk_snd's Avatar
Just what I needed! Thanks for the info man!
Old Sep 27, 2012 | 03:02 PM
qwk_snd's Avatar
See, I was considering these wheels, but it looks like with only 4.5" of backspacing that they'd most likely be sticking out instead of tucking nicely... huh? :/
Series 1069 - Polished Alloy Wheel
Old Oct 10, 2012 | 05:10 PM
xx_ED_xx's Avatar
I think mine are 4.5 bs not sure they fit flush 10 inch wheel, can check when i get back from afghanistan
