3.42's in a 2500HD?
Old Feb 8, 2006 | 10:09 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Default 3.42's in a 2500HD?
Do you guys think a '05 2500HD (ext-cab shortbed 2wd 6.0L) could push itself down the road with a set of 3.42 gears in it? And make better gas mileage?
Does anyone make 3.55 gears for the 10.5" 14-bolt?
Old Feb 8, 2006 | 10:14 AM
zippy's Avatar
i think it could with the 3.42's. it wouldn't be usefull for any of it's HD functions though.
Old Feb 8, 2006 | 11:16 AM
Neil 6.0's Avatar
Well...yes and no. If you want to tow something you could just put the shifter in 3rd gear and it would be equivalent to having 4.10's with the shifter in 4th gear. Sure it will take alot more throttle to get a load moving from a dead stop, but at highway speeds it would basically be the same.
This truck will mostly be a highway runner on flat open roads with occassional (once or twice a month?) towing of livestock/farm trailers.
Old Feb 8, 2006 | 12:29 PM
zippy's Avatar
with a 2.48 first gear that's going to keep the truck into the stall of the converter for quite a ways before smoothing out to lock the converter in. on the highway you'd end up with constant 3-2 shifting. with a 3.42 gear in an HD i wouldn't recomend any more than about 5500lbs towing.
flatblack83
Jan 3, 2026 07:10 PM
BlownHD
Oct 3, 2015 12:24 PM
Cammed4ever
Sep 30, 2015 03:38 PM
69z-28
Sep 21, 2015 07:31 AM
zblee
Sep 17, 2015 07:58 AM
