3.42 with a 4l80e
Old Apr 1, 2014 | 08:49 PM
  #21
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by hsiriyob
Thanks for the response. I'm looking for a street gear. With the 4:10's I have little use of my first gear and my engine spins 2500-2600 at 70. 30" tire. I'd like to drop my rpms to about 2000 witch is the 3.42. I'll look at the 3.73 and see what the rpms look like
If your 4L80 with a 30 inch tall tire:
3.73 will put you around 2200 RPM
3.42 will put you around 2000 RPM
HTH
I still like the 3:73 with the 4L80E
The 1 truck I drove with 3:42's and an 80E was a turbo and I still didn't like the gear ratio. I think the tire ratio was smaller too.
Old Apr 1, 2014 | 09:02 PM
  #22
Suburbazine's Avatar
Is your tire size 26 inch tall with the 4L80?
Yes. 235/50ZR16.
http://imagizer.imageshack.us/v2/800...0/819/miq3.jpg
Old Apr 3, 2014 | 03:03 PM
  #23
Fast355's Avatar
Anybody running a 3.42 with the 80e. I like the idea of cruising at 2000 rpms, but im not sure if its the best fit for my setup?
I had a 10 bolt 3.42 behind my cammed 330 RWHP 5.7/4L80E in my Express with the B82 factory converter that stalls ~2,400. Maybe it was the 6,200 lbs curb weight, but it was a slug compared to the S10 stalled 4L60E that was in it before. When I broke a spider gear I put a 3.73 geared 14-bolt in its place. Considering regearing to 4.10s soon. Being able to run 50 mph in 1st gear and over 90 mph in 2nd @ 5,500 rpm is pretty cool though.
Old Apr 3, 2014 | 03:30 PM
  #24
Ferocity02's Avatar
I have 3.42s and 31" tires and it's not that bad around town. My commute is mostly highway so that's mainly why I went with them.
Old Apr 3, 2014 | 06:16 PM
  #25
hsiriyob's Avatar
HTH
I can live with a couple hundred more rpm's. I thinks the 3.73 is going to be a good compromise! t6axis also recommended the 3.73's...
Old Apr 3, 2014 | 08:11 PM
  #26
1FastBrick's Avatar
In my Opinion I think there a good all around choice.
Old Apr 6, 2014 | 02:30 AM
  #27
Ron_Stoppable's Avatar
im so glad i read this, i thought something was wrong with my setup. i have an 80e in my s10 with 3.42s and it feels like a slug off the line, much better when its rolling though. im swapping to a 8.8 with 3.73s so hopefully thatll cure my issue.
Old Apr 6, 2014 | 05:38 PM
  #28
axisT6's Avatar
Find out what width the Cadillac brougham (sp?) 14 bolt width is. It would be cool if it was narrow enough to fit an S10.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
RustyD
May 23, 2016 07:04 PM
AdaMax
May 16, 2016 11:35 PM
turbo6c3
Oct 5, 2015 06:11 PM
jscherbs
Sep 30, 2015 07:54 AM
