2nd Gear "only" Trans Slip 4l65e
Old Dec 10, 2007 | 06:23 PM
BlackSSS's Avatar
Default 2nd Gear "only" Trans Slip 4l65e
Just recently noticed a slip in the tranny in 2 gear only....slips for a couple of seconds then catches. This is only once I am already going and give it PART throttle. If I take off from a dead stop and run first of to redline and stay in it slams into 2nd hard like it always has with NO slip...?? Again this is the only gear it happens in and DOES NOT do it unless I have just shifted into second cruising slow and get into the throttle some.
The trans is built with high end hard parts along with a zpak set of clutches.
I am thinking maybe the pressure solenoid and/or band for 2nd is going out..???
Anyone have any experience with this?
Thanks in advance
Old Dec 10, 2007 | 07:16 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Those are just a couple of things... How about 1-2 Accumulator piston. Those were plastic ones that are prone to cracks (if your built trans has one). Also, I think if there's any seal issues with the servo, that'll play a role too. I'm in the habit of considering EVERY possible factor. I don't know if any builder will say definitively without looking at the trans.
If it doesn't slip going into 4th, I'd think less likely of the 2-4 band (or rev input drum) as a cause. Just my $0.02. I'm just an amateur.
Old Dec 10, 2007 | 08:04 PM
BlackSSS's Avatar
"How about 1-2 Accumulator piston"
Yeah, I thought that may be a possibility too.
getting it check tommorow.
Old Dec 10, 2007 | 08:18 PM
FLT's Avatar
FLT
FormerVendor
If in fact it is the 1-2 acc piston, lets hope we have not hurt the band. Take a look and lets see what you find. Vince
Old Dec 10, 2007 | 10:59 PM
BlackSSS's Avatar
Hey Vince, PM me a price on a built 80e
Thanks
Old Dec 10, 2007 | 11:00 PM
BlackSSS's Avatar
Thanks
and do you take trade-ins?
Old Dec 11, 2007 | 07:26 AM
FLT's Avatar
FLT
FormerVendor
PM sent and we do buy cores if it makes sence. Vince
Old Dec 14, 2007 | 08:27 PM
BlackSSS's Avatar
Smile
Thanks in advance
GOOD NEWS:
Ahhhh I was RIGHT! The EPC switch/solenoid was bad. Sumbi@$$ shifts VIOLENTLY now!!
BAD NEWS:
Got bent over! $400 to remove valve body and replace epc!!!!!
Old Dec 14, 2007 | 08:43 PM
FLT's Avatar
FLT
FormerVendor
OUCH! To replace the epc once the pan is down it takes only a few minutes. Did they pull the valve body because the did not know the solenoid was bad?
Old Dec 14, 2007 | 11:43 PM
BlackSSS's Avatar
Yes, they said they "extensively went through the valve body" lol
ferrellrooster
Mar 6, 2025 03:22 PM
Oobray
Jun 13, 2022 03:38 AM
Raggedz71
Jul 29, 2016 10:20 AM
1slwgto
Aug 16, 2015 06:40 PM
Dezert1500
Jul 30, 2015 02:51 PM
