View Poll Results: any recommendations? so i wont have to deal with any 4l60s
notch and lower more?
0%
driveshaft?
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
2008 nnbs cc 4l60e transmission bad angles
Old Jun 23, 2022 | 10:10 PM
1FastBrick's Avatar
Custm2500's Rude Friend
That yoke may have bottomed out and damaged the seal inside the yoke.
Also the out side of the seal surface doesn't look smooth in the 1 image where the shaft is pulled back. If its not smooth, It will wear the output shaft seal and leak.
I can't tell from the video if its leaking from the inside of the yoke or if its leaking at the outer seal.
Old Jun 23, 2022 | 10:20 PM
1FastBrick's Avatar
The yellow arrow is what I am referring to about the yoke and the output seal.
Old Jun 23, 2022 | 10:26 PM
1FastBrick's Avatar
From the Video, It appears it is leaking from the center of the Yoke.
Old Jun 24, 2022 | 04:05 AM
Bgbldodge's Avatar
I believe there is a seal in there that can go bad.
Old Jun 24, 2022 | 06:53 PM
alejandrohd's Avatar
Registered User
the last two pictures is how the old transmission was leaking and after went out
the first picture is of how the new transmission is sitting right now and only leaks on uphill
replacing it will fix it from leaking and the angles?
Old Jun 25, 2022 | 12:57 AM
1FastBrick's Avatar
The Angles is something you have to measure and tell us. That's not causing it to leak though.
Johnny Wolf
Sep 23, 2016 10:55 PM
AlwaysOnKill
Feb 25, 2015 07:35 PM
mikeith
Sep 29, 2010 09:24 PM
mikeith
Jul 9, 2010 11:57 PM
peterls1
Aug 23, 2008 12:44 AM
