nnbs 5" rear drop problems
Old Jul 8, 2010 | 10:08 PM
mikeith's Avatar
Default nnbs 5" rear drop problems
ok i got my truck lowered yesterday and i noticed a few things that have me a little concerned. when the truck was at stock hight the driveshaft had about 1" forward play to allow the u-joint to easily slip out of the yoke. but when i went to put it back in the yoke i literally had to rotate the axle upward a little and to get the u-joint back in the and had to use a decent ammount of pressure to pull it back strait. now instead of having about and 1" of play there is actually some tension. is this normal?
it sounds like the rear is making a couple popping noises when i leave a stop and i dont know its due to the problem from above or from a bad pinion angle?
Old Jul 9, 2010 | 03:44 PM
iamkeniff's Avatar
sounds like a bad pinion angle. also the driveshaft may have to be shortened but i doubt that. GMFS.com is where they have a lot of dropped trucks. im doing a 4/6 soon i hope i dont run into this problem. check out the ubolts and make sure they are tight.
Old Jul 10, 2010 | 07:55 AM
mikeith's Avatar
Yeah but a bad pinion angle wouldn't cause the driveshaft to be too tight... If anything it would cause it to be too loose since the angle is off
Old Jul 11, 2010 | 03:33 AM
Daryn's Avatar
Formerly darynC-10/23/10
if you put a drop on it and the driveshaft is tight, you need to shorten it before you fudge up your transmission.
Old Sep 29, 2010 | 09:24 PM
BIG_D_74's Avatar
I have full air ride on my truck. At ride height its equivalent to about a 4/6 drop and before I set the pinion angle I got an occasional pop. It was only noticeable under load. I'd check that out like iamkeniff said.
chopperloco
Jul 10, 2016 10:45 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Ketis
Jul 23, 2015 12:37 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
121
Jul 16, 2015 12:18 AM
