2004 Silverado Suspension question?
Old Mar 26, 2008 | 08:16 PM
LS6_Silverado's Avatar
Can this be a do it your selfer replacing the shocks? all i need is a set of jackstands and two jacks right? Im a newb when it come to suspension, Thanks
Old Mar 26, 2008 | 10:33 PM
fastnblu's Avatar
Support as needed @ the correct points on frame &/ or under rear axle hsg. I believe you want to support so weight is unsprung. I might not be saying that correctly. Others may add their .02. I sprayed w/ WD40 (use whatever)...both a day or so b4, & the day of susp. work. But I'm up north too & didn't want to fight rust. Raise enough so shocks(FRONT) drop out bottom. Top mount may give fits. Reinstall new.
(REARS)At rear, do 1 side at a time. Stay out from under axle housing so it doesn't drop down on you. Support axle &/or frame to unload suspension I believe is the term. If you have impact, the might need it. Replace & tighten. Lower onto ground. Retighten, I believe its called preloading. How'd I do guys?
Shocks is all you are doing, right?
Old Mar 27, 2008 | 12:14 AM
yea im just going to try one thing at a time so i can see what improves.
Old Mar 27, 2008 | 01:21 AM
simple02's Avatar
Just a suggestion but check to make sure you still have your swaybar end links attached. I have read of them just coming off (mainly after front control arm modifications) but you never know.
Old Mar 27, 2008 | 10:33 AM
fastnblu's Avatar
Sounds like a good plan. Keep us posted or if more Q's, fire away, & we'll try to answer. Good luck!
Old Mar 27, 2008 | 01:54 PM
KySilverado's Avatar
I was going to suggest shocks and check the sway bar end links also.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
chopperloco
Jul 10, 2016 10:45 PM
Castro45
24
Jul 31, 2015 07:13 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
