2004 Silverado Suspension question?
Support as needed @ the correct points on frame &/ or under rear axle hsg. I believe you want to support so weight is unsprung. I might not be saying that correctly. Others may add their .02. I sprayed w/ WD40 (use whatever)...both a day or so b4, & the day of susp. work. But I'm up north too & didn't want to fight rust. Raise enough so shocks(FRONT) drop out bottom. Top mount may give fits. Reinstall new.
(REARS)At rear, do 1 side at a time. Stay out from under axle housing so it doesn't drop down on you. Support axle &/or frame to unload suspension I believe is the term. If you have impact, the might need it. Replace & tighten. Lower onto ground. Retighten, I believe its called preloading. How'd I do guys?
Shocks is all you are doing, right?
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Castro45
24
Jul 31, 2015 07:13 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
