2001 transmission line question
Old Sep 28, 2009 | 04:09 PM
TXsilverado's Avatar
Default 2001 transmission line question
2001 silvy...
which transmission line is the feed and which one is the return. i want to check how my stuff is configured. i just kind of guessed and went. i want things as cool as possible before my new converter makes it in there.
Old Sep 28, 2009 | 04:10 PM
BlackGMC's Avatar
Resident Retard
I bypassed the radiator completely and just ran it threw the TruCool 40k.... I am assuming that yours is still attached to the rad.
Old Sep 28, 2009 | 04:14 PM
i want it attached to the radiator so it will warm up in the mornings. i had it completely bypassed and in the winter it wouldnt warm up at all...no warm up equals no lock up. pain in my *** lol.
Old Sep 28, 2009 | 04:19 PM
BlackGMC's Avatar
Resident Retard
Really, i have had no problems with mine locking up. With as loose as mine is, and i am sure yours is preety loose as well, they generate their own heat rather quickly without the aid of the radiator, but all trucks are different i guess....
Also i had a gauge inline before the rad and cooler directly in the line out of the trans and the temp would shoot up rather quickly, even thou the computer thought it was ALOT cooler.. For example at the track starting temp at the line was 140ish and the end of the run it was 190ish, the computer went from 140ish to 150ish.... Basically anytime the TC was unlocked it was generating heat....
Anyways I belive the bottom line on the tranny is the feed and the top is the return... So i believe your cooler should be after the top line...
Old Sep 28, 2009 | 04:44 PM
Cuerva's Avatar
11 Second Truck Club
Bottom line is feed and top is return.
Old Sep 29, 2009 | 05:26 AM
nope...my converter is extremely tight. i can only brake stall to 2300 ish rpm before i spin over the drag radials. i lock it up pretty really early too. 40 mph. keeps things cool
Old Sep 29, 2009 | 05:27 AM
thanks! exactly what i was looking for
Old Sep 29, 2009 | 07:36 AM
silver-mod-o's Avatar
Hunt&Fisherator
You haven't swapped to hoses yet Stew?
Old Sep 29, 2009 | 09:00 AM
nope. whats the advantages? i just use the OEM lines.
Old Sep 29, 2009 | 11:46 AM
budhayes3's Avatar
PT's Slowest Truck
+1, top is the return, on both the trans and the radiator
