Is 2001 and oddball year for 4L60 trans?
My friend just bought a 01 ext. cab 2WD truck with a 4.8L. He was told that there is a pin in the trans that has come loose and not to drive it cause if the pin lets go there is a good chance it will destroy the trans to the point of not being able to repair. So he phoned some scrapyards to see if he could get one and he has been told they are different for some reason. Would you guys know the difference by chance? I would think as long as it is 2WD and say 1999 and up they would all be the same.
Exactly what i was thinking. I cant seem to be able to think of what pin is the problem they are telling him about. I have been in those transmissions my fair share for sure. So, i dont know what these guys are talking about.
Mechanical speaking they are the same with minor changes internally.
How ever the bell housing, input shaft and converter could be different if it was attached to a different Engine such as a the older 5.7L or a 4.3L
Even though they introduced the NBS trucks in 1999 they continued the the OBS trucks into 2000 with the older engines. To keep it simple from a parts stand point, They will Just say the 2001 up will retro fit.
As long as its 99- up from the same body style and engine platform you should be ok.
Obviously 2wd and 4wd will have different output shafts so you should stick to the same there.
the 4L60E, 4L65E and 4L70E should all retro fit back in the 99-up bodystyle
But if you truck was equipped with the 4L70E in the later years starting in 2006 you can not swap the other 2 in because the 4L70E has an input shaft sensor and the computer needs to see that signal.
The RPO codes for the 4 speed transmissions are:
M30 = 4L60E
M32 = 4L65E
M70 = 4L70E
MT1 = 4L80E
M30 = 4L60E
M32 = 4L65E
M70 = 4L70E
MT1 = 4L80E
copied from this thread https://www.performancetrucks.net/fo...ec-max-459954/
Info - New Product Announcement - 4L70-E (M70) Automatic Transmission #05-07-30-026 - (Oct 7, 2005)
2006 Chevrolet Silverado, TrailBlazer SS
2006 GMC Sierra
with 4L70-E Automatic Transmission (RPO M70)
General Motors Powertrain required a version of a current production rear wheel drive transmission capable of handling higher torque and horsepower without going to a larger size transmission. As a result, the 4L70-E was created. Very much like the 4L65-E, the 4L70-E shares many of the same components and adding premium materials and additional manufacturing processes, the 4L70-E is capable of handling up to 400 horsepower and 430 foot-pounds of torque. It is also capable of increasing shift speeds up to 6000 rpm.
The 4L70-E will be first introduced in some 2006 mid-size sport utilities and full-size pickups. The 4L70-E will be identified as RPO M70. The M70 will use the large 300 mm (101K or 112K) torque converter. Some M70 models will be the first 4L60 series transmissions to receive the new input speed sensor (ISS) .
Below are the 2006 4L70-E applications and models:
• Sport Utility 4L70-E models with ISS: SKD/TKD
• Full-Size Pickup 4L70-E models: CMD, CWD & KMD
Important: The following graphic and table describe only the essential components that make up the M70 transmission model and will not identify all parts.
The following identifies the 4L70-E (M70) components and the components it shares with the 4L65-E (M32) transmission.
Item Number
Part Description
ID Feature
RPO M32
RPO M70
1. 300 mm/112K Torque converter (1)
• Identification code label affixed to the convert cover
• Outer diameter & lug size
X
X
2. 5-Pinion input carrier Asm. (662)
Number of pinion gears
X
X
3. 7-Plate 3-4 Clutch Asm.
(7 friction, 6 steel plates)
• Number of friction plates
• Steel & apply plates have "HD" stamp
• Friction plates have Identification stripe
X
X
4. 5-Pinion Reaction Carrier Asm. (681)
X
X
5. Reaction Internal Gear Asm. (684)
3 machined grooves
X
6. Output Shaft (687)
One identification band
X
7.
HD Low and Reverse Roller Clutch Asm.
Bronze clad cage
X
X
8. Input Sun Gear and Forward Sprag Asm (642)
Paint marking
X
X
9. Input Turbine Shaft
X
X
10. Stator Shaft
Darken splines
X
X
Refer to the appropriate SI section for additional repair, diagnosis or description information.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
.© Copyright General Motors Corporation. All Rights Reserved.
2006 GMC Sierra
Item Number
Part Description
ID Feature
RPO M32
RPO M70
X
X
X
X
X
X
X
X
3 machined grooves
X
X
7.
Bronze clad cage
X
X
Paint marking
X
X
X
X
10. Stator Shaft
Darken splines
X
X
SLOPONY
20
Oct 18, 2016 06:05 AM
rojeho
Aug 8, 2015 07:20 PM
